Rear Finish Mower Changing gear oil on Caroni/First Choice/Sicma Finish Mower?
   / Changing gear oil on Caroni/First Choice/Sicma Finish Mower? #1
tillboy2001
Hi,
I just picked up one of these in the 72" width the other day. I haven't had much time to look at it but when I glanced at the gear box, I didn't see what would appear to be a drain plug. I do see a sight glass on the side and I assume that's not supposed to be removed and it wouldn't be at the bottom anyway to allow it to drain completely. My question is, is there really a drain plug on these somewhere (if you own one chime in) or do you just have to suck out the old fluid when changing the gear oil in th e gearbox?
   / Changing gear oil on Caroni/First Choice/Sicma Finish Mower? #2
I don't know about that specific mower, but my cutter/brush hog doesn't have a drain plug. I think most people use something like this to pull the used grease out of the fill hole:
Oil Suction Gun
It's what I use and it works great.
There's at least one guy on here that flips his cutter over to drain it. I'm not that brave.
Yeah I don't think I'll be flipping it over :) I'll stick with sucking it out. I already have a hand operated pump to do this. Just wanted to make sure that was the only way.
   / Changing gear oil on Caroni/First Choice/Sicma Finish Mower? #4
Something I use on my gear boxes to get the oil out is my turkey baster from the kitchen . I keep it hidden in the barn now.
   / Changing gear oil on Caroni/First Choice/Sicma Finish Mower? #5
I have a Sicma. I replaced the fluid after a couple hours and replaced it with synthetic,75w-90 at Ken Sweet's suggestion.
I used a suction bulb, attached to a small diameter, clear, siphoning hose. It worked well. Took about 45 minutes to empty itself.
   / Changing gear oil on Caroni/First Choice/Sicma Finish Mower? #6
If the gear box uses oil, I would consider, drill, tap, plug. Also I would cross drill the plug for safety wire.
20ft Shipping Container (A51573)
20ft Shipping...
1997 JOHN DEERE 544G WHEEL LOADER (A52472)
1997 JOHN DEERE...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
