Changing from 6 to 12 volts
   / Changing from 6 to 12 volts #1
tallyho8
Elite Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
A friend bought a 1941 Model M Farmall 3 wheeler that a neighbor had and he is trying to fix it up. I have noticed some 12 volt changeover kits for sale and they come with an alternator but not a starter. Can you use 12 volts on a 6 volt starter without burning it up?
   / Changing from 6 to 12 volts #2
A reasonably healthy 6 volt starter will get by very well on a 12 volt diet. Convert if you want to, and leave the starter alone until it requires attention. It could last for years.
   / Changing from 6 to 12 volts #3
A lot of the Ford guys leave the Starter as is... sometimes it's a little harder on the Bendix Drive... the armature and field coils don't seem to have a problem.
   / Changing from 6 to 12 volts #4
Another option is to use two 6 volt batteries in series. Charge 12 v across both batteries, run 6 volt needs off "first" 6 v battery.
Used to use this set up for 12 volt Corvair engine in 6 volt VW bug back in the day.
   / Changing from 6 to 12 volts #5
If my old memory serves me right, DC motors don't care if it runs on 6,12,18,24 volts. If the insulation is good, they just spin faster with more volts.
   / Changing from 6 to 12 volts #6
Better than 15 years ago, I up graded a 1953 Super C Farmall
to 12 volt. Used Chevy. alternator with internal regulator. Had to make
some brackets etc. and use a double V pulley to drive it. Never had a
single problem with the change over. The starter is still the original
6 volt unit. Only thing ever replaced was the battery 2 or 3 times.
elad
   / Changing from 6 to 12 volts #7
There should be no issue.
At one time, JC Whitney actually sold a 6 Volt alternator. I used on an old Farmall that I didn't want to do a full change over (had to make it negative ground.)
Make sure you remember to check the ground of the battery. I think the older tractors were a six volt POSITIVE ground. So you'll have to swap the AMP guage connections, swap the coil and connections, etc, etc.....
   / Changing from 6 to 12 volts #8
I'd also leave the 6v starter as Rick and the others said. I've got plenty of fords with 6v starters and 12v 'kits'.
Big copper in a 6v starter.
soundguy
   / Changing from 6 to 12 volts #9
I switched my 1943 2N from 6 to 12 volts many years ago. As Soundguy points out, the 6 volt starter will work just fine. I have had no problems.
Terry
   / Changing from 6 to 12 volts #10
tallyho8, You don't mention whether the M has lights. If so the bulbs will need to be changed. Also my memory is a little vague but I recall that the 6 volt voltage regulator is in the pod that has the light & ignition switches ???? You may need to eliminate that circuit ?? MikeD74T
2017 John Deere 652R (A50123)
2017 John Deere...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2021 Harley-Davidson FLHP Motorcycle (A51694)
2021...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
