Changing from 6 to 12 volts
   / Changing from 6 to 12 volts #1
tallyho8
Elite Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
A friend bought a 1941 Model M Farmall 3 wheeler that a neighbor had and he is trying to fix it up. I have noticed some 12 volt changeover kits for sale and they come with an alternator but not a starter. Can you use 12 volts on a 6 volt starter without burning it up?
   / Changing from 6 to 12 volts #2
A reasonably healthy 6 volt starter will get by very well on a 12 volt diet. Convert if you want to, and leave the starter alone until it requires attention. It could last for years.
   / Changing from 6 to 12 volts #3
A lot of the Ford guys leave the Starter as is... sometimes it's a little harder on the Bendix Drive... the armature and field coils don't seem to have a problem.
   / Changing from 6 to 12 volts #4
Another option is to use two 6 volt batteries in series. Charge 12 v across both batteries, run 6 volt needs off "first" 6 v battery.
Used to use this set up for 12 volt Corvair engine in 6 volt VW bug back in the day.
   / Changing from 6 to 12 volts #5
If my old memory serves me right, DC motors don't care if it runs on 6,12,18,24 volts. If the insulation is good, they just spin faster with more volts.
   / Changing from 6 to 12 volts #6
Better than 15 years ago, I up graded a 1953 Super C Farmall
to 12 volt. Used Chevy. alternator with internal regulator. Had to make
some brackets etc. and use a double V pulley to drive it. Never had a
single problem with the change over. The starter is still the original
6 volt unit. Only thing ever replaced was the battery 2 or 3 times.
elad
   / Changing from 6 to 12 volts #7
There should be no issue.
At one time, JC Whitney actually sold a 6 Volt alternator. I used on an old Farmall that I didn't want to do a full change over (had to make it negative ground.)
Make sure you remember to check the ground of the battery. I think the older tractors were a six volt POSITIVE ground. So you'll have to swap the AMP guage connections, swap the coil and connections, etc, etc.....
   / Changing from 6 to 12 volts #8
I'd also leave the 6v starter as Rick and the others said. I've got plenty of fords with 6v starters and 12v 'kits'.
Big copper in a 6v starter.
soundguy
   / Changing from 6 to 12 volts #9
I switched my 1943 2N from 6 to 12 volts many years ago. As Soundguy points out, the 6 volt starter will work just fine. I have had no problems.
Terry
   / Changing from 6 to 12 volts #10
tallyho8, You don't mention whether the M has lights. If so the bulbs will need to be changed. Also my memory is a little vague but I recall that the 6 volt voltage regulator is in the pod that has the light & ignition switches ???? You may need to eliminate that circuit ?? MikeD74T
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
TRUCKING INFO (A50775)
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
