Changing filter?
/ Changing filter? #1
NIXON
Veteran Member
West Sunbury ,Pa.
L3130 hst
I've got to change the Hydro,and trans filters . Can I do it without draining the Sudt from the tractor ?
/ Changing filter? #2
I changed the hydro and trans filters on my L3240HST without draining first. Used less than 1 gallon SUDT to "top off" after change. Tractor was parked on flat surface during filter change.
/ Changing filter? #3
Just wondering, Why change the filters only?
/ Changing filter? #4
Because transmission/hydraulic fluid does not become contaminated with combustion by products like engine oil does.
By the way, I bounght a gallon of UDT Monday and it was $22. OUCH
/ Changing filter? #5
I replaced the filter on my B2320 for the 50 service without draining it. I just took the old one off and put the new one as quickly as possible. I then topped it off. This is how my dealer told me they do it.
/ Changing filter? #6
The only advice I could offer would be to flip the tractor upside down, change the filters quickly and then right side up the beast. :eek:
Nix, what I really wanted to say, on this 'Veterans Day' was to give you a shout-out and say 'thank you' to you and your military family for their service to our Country. ....and thanks to all the military veterans out there for your service to our Country, the good ole USA!
Don
/ Changing filter? #7
1* I just took the old one off and put the new one as quickly as possible. I then topped it off.
2* This is how my dealer told me they do it.
1&2* Not a good way to do the 50 hour service.
/ Changing filter? #8
I agree Mr Brown unless the owners manual says different. I changed out all my fluids and filters at 50 hours as per the manual and which I thought was the most critical with all the metal shavings in the break in period.
/ Changing filter? #10
The manual for my 5030 says to change the filters and fluid for the 50 hour service including the front axle fluid. The manual for my 5740 which is a year newer says to change the filters only at 50 hours and leave the front axle fluid until 400 hours.
/ Changing filter? #11
Just did the 200Hr at 225Hrs on L3130GST by changing filter and just catching the draining oil and reusing. Was supprised at the metal sludge on the magnet on the filter and how hydraulic performance increased, at 50Hrs the oil was darker and it did need changing then, if anyone tells you different you need to find somebody else for service. The Kubota recomended intervals are pretty accurate as to how dirty the oil is on all my equipment so far.
David Kb7uns
/ Changing filter? #12
Just changing the filter leaves all those
metal shavings in there.
Change the fluid too an get them out of there.
/ Changing filter? #13
If you leave the filler plug and the dipstick in very little wll run out. I did it on my BX and only lost the oil in the filter.
/ Changing filter? #14
I just did my 50 hour service this weekend. The UDT fluid looked poor and the filter was plugged with stuff that looked like what might come out of your dryer. I've never seen such a plugged filter in my life.
The udt oil looked like there were granules in a choloidal suspension.
I would change it all the first time. After that, I'll change the filters frequently and the fluid every other time.
/ Changing filter? #15
If you do it like I did (L4330), after you finally break the filter free (they are usually on TIGHT), the filter will spin right off, then some modest amount of fluid will begin draining while you grab the new filter, and only then will you discover that some long-ago-hit branch has mashed one of the rigid hydraulic lines so that it JUST BARELY interferes with threading the new filter on.... starts to cross-thread.... more fluid pouring out.... starts to cross-thread a second time... MORE fluid pouring out.... try to pry the line outta the way with a stick... stick breaks... MORE fluid pouring out. Finally got wife to slightly pry the line out of the way and got the new filter on. Only lost about 2 1/2 gallons. Of $$$ SUDT! #&^%$**!
- Jay
/ Changing filter? #16
The manual called for filter only on my B2320. I asked two local dealers how they did it and both said that they only performed filter change on the 50 hour service. Very little metal and the fluid looked good. Others may disagree, but I saw nothing that would justify the added expense. JMO...
/ Changing filter? #17
I just had to change my non-OEM filters to Kubota filters w/o draining the fluid.
Just have the replacement filters nearby and unscrew one and screw the other one as fast as you can.
I lost around 1/2 gallon.
Please use OEM filters for the Hydro (see my post on noisy hydro pump).
Good luck.
