Changing dust boot on tie rod - MX5100
   / Changing dust boot on tie rod - MX5100 #11
Last set I did was a couple of years ago, I made an alignment jig by welding a section of old bed frame together that fit snugly against the rims, after replacement I just used the jig to set the wheels exactly where they were prior to repair.
   / Changing dust boot on tie rod - MX5100 #12
It happens. As others have said count the exposed threads and measure when done. I back the nit off a bit and then put a block of wood under and give it a love tap with ha mallet to get the end out. Where this is new you should have no problems.
On the new larger masseys they put the steering stuff behind the front axle. I wish knots would have done that.
I finished the repair this weekend. Posting a few photos. I used the loader to raise the front and put a jack stand under the axle on the repair side only. No need to take off the tie rod completely. Just loosen the jam nut and the threaded end unscrews from the fitting. After that, taking the old boot off and putting on a new one is pretty easy. The retaining ring on the engine side is a bit of a pain. Use some of the lube from the joint and it will eventually slip on. I used a permanent marker to mark the threads before unscrewing. Just getting it within a thread of proper alinement. With R1 tires and a low speed vehicle off road, you won't know the difference.
Cheers,
HP
   / Changing dust boot on tie rod - MX5100 #14
Thanks for the update, I may just get around to doing mine this winter.
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
