Changing blades on a Kioti 72 in. finish mower
   / Changing blades on a Kioti 72 in. finish mower #1
JDL538
California Ky.
CK 30
I've tried every way I know and can't get the blade off.. Any one have one of these. I think it's a 2013 model bought it in June this year. Thanks for any help.
   / Changing blades on a Kioti 72 in. finish mower #2
Impact wrench.
Does anyone know if it's right or left thread?
   / Changing blades on a Kioti 72 in. finish mower #4
That will depend on which way the blades turn.
Does that mean it's the opposite of the way the blade turns ?
   / Changing blades on a Kioti 72 in. finish mower #6
I think it should loosen the opposite way the blade turns, but I'm not 100% sure.
   / Changing blades on a Kioti 72 in. finish mower #7
My 48" version of this mower has standard right hand threads and I use a battery powered impact wrench on it without issue.
Rancho
Rancho
Do You stop the blades from turning some how ? If I put a socket on the nut on the top it will just turn. If I stop the blades with a 2x4 it will just slip without the bolt giving..
   / Changing blades on a Kioti 72 in. finish mower #9
I had to grab the pulley neck with a pipe wrench to get mine off, miserable hot day job that I would have done differently in hindsight, like maybe using a bunch of penetrating oil first.
Mine were regulare righty tighty lefty loosy nuts
   / Changing blades on a Kioti 72 in. finish mower #10
My three blades are held on by NUTS (the type with nylon inserts), and I do hold the blade with my hand during this process, but it does not require any real pressure.
Rancho
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A52472)
MCELROY 500 SERIES...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
