changing antifreeze
/ changing antifreeze #1
cabin kioti
Sullivan County Pennsylvania
ck 30 hst
I own a CK30HST and I need to replace the block heater. For some reason it stopped working over the weekend. The tractor is an hour drive from my home and a long way from town when I get there. All my manuals are with the tractor and I will need to drain the anti freeze and I should replace it with new antifreeze. What I need is the capacity of the cooling system. I think it is 11 quarts but not sure. Thank you all.
/ changing antifreeze #2
You should be able to do it without loosing all the antifreeze and just have a quick top up. I don't have my CK30 manual anymore, but it has been posted here on TBN so you should be able to find it with a search.
/ changing antifreeze #3
My CK30hst is a 2004 model. My manual advises 2.1 gallons for the antifreeze.
/ changing antifreeze #4
I'd take 3 gallons, and a couple of water too. You don't want 100% coolant, you want about 60%coolant/40%H20.
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
(2) STAINLESS STEEL HOG FEEDERS (A64278)
(2) STAINLESS...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
