changing antifreeze
   / changing antifreeze #1
cabin kioti
Bronze Member
Sullivan County Pennsylvania
ck 30 hst
I own a CK30HST and I need to replace the block heater. For some reason it stopped working over the weekend. The tractor is an hour drive from my home and a long way from town when I get there. All my manuals are with the tractor and I will need to drain the anti freeze and I should replace it with new antifreeze. What I need is the capacity of the cooling system. I think it is 11 quarts but not sure. Thank you all.
   / changing antifreeze #2
You should be able to do it without loosing all the antifreeze and just have a quick top up. I don't have my CK30 manual anymore, but it has been posted here on TBN so you should be able to find it with a search.
   / changing antifreeze #3
My CK30hst is a 2004 model. My manual advises 2.1 gallons for the antifreeze.
   / changing antifreeze #4
I'd take 3 gallons, and a couple of water too. You don't want 100% coolant, you want about 60%coolant/40%H20.
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
