Box Scraper Changing angle to use rippers only
   / Changing angle to use rippers only #51
I thought about this a while. Went out and checked my LPGS and ROBB. Both units have ripper shanks.
I lower the shanks on both units enough so that they will be digging while the implement is dead level. As a matter of fact - that is the way the manufacturer recommends. No tip, tilt or angle. If I wanted shanks only - I can roll the ROBB and have that. I could raise the LPGS so the only thing touching the ground would be the shanks. That would NOT BE a good way to operate the LPGS.
Most implements with rippers are NOT designed to be used with rippers only. The basic implement alone or with rippers down. My ROBB is the exception.
   / Changing angle to use rippers only #52
If I am understanding the op correctly, you cannot expect your bb to work like that. You must buy a hydraulic bb or deal with your rippers being up and down. You cannot expect you bb to do something it is not designed to do.
When I rip, my rippers are down. When I don't rip, my rippers are up.
UNUSED FUTURE SB05 MINI HYD BREAKER (A57193)
UNUSED FUTURE SB05...
2008 41ft KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 41ft KZ...
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2007 Yard Dump Truck (A55973)
2007 Yard Dump...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
