changing a massey 65 mk1 wheel bearing
   / changing a massey 65 mk1 wheel bearing #1
nightcrawler
somerset
massey ferguson 65 mk1
Hi all I've got a 65 mk1 and on the inside of the hub at the top there is a 1/8" gap that opens and closes when pushing on the top of the tyre. i presume this is the wheel bearing worn out? i have ordered the parts anyway but need to know what tools will be needed and how to do it? I am new to this so idiot proof advice would be a great help! the wheel hub is the one with wheel nuts and not bolts.
many thanks! Mat.
   / changing a massey 65 mk1 wheel bearing #2
If it's the hub you will need a wrench big enough to remove the nut under the cap. A crescent wrench is fine as you can use that to remove the cap. You will also need a hammer and punch to remove the outer races. Go to you tube and watch any video about replacing wheel hub bearings. That should help too.
Any pictures?
Thanks. Sounds simple. Hopefully the parts are here tomorrow and I can have a go. If I get stuck I'll take some pics of my pile of bits!
Thanks for advice!
   / changing a massey 65 mk1 wheel bearing #4
Getting the outer races out is the hard part. The getting the new race in is the second hardest. Did both of my front hubs and kingpins last summer. I probably replaced the original stuff.
2013 JOHN DEERE 470G LC EXCAVATOR (A51246)
2013 JOHN DEERE...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A53472)
NEW 2022 Load...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
