changed hydraulic/trans fluid. It calls for 8gal still need more after 12gal?
   / changed hydraulic/trans fluid. It calls for 8gal still need more after 12gal? #1
2LateIWon
AGCO/CAT Challenger MT275
So I changed the tranny/hydraulic fluid last night. The manual calls for like 8.7gal of fluid I put in almost 12 gal and it is still not showing up on the sight glass. First I made sure no leaks :)thumbsup:) then I started it up and ran it around the yard a bit eveything works fine no wierd nosies but it's still not showing up on the sight glass.
I do have an aftermarket FEL but I didn't think it would call for that much extra fluid.
What should I do keep filling it?
p.s. I have a Challenger MT275 with ML30 loader
   / changed hydraulic/trans fluid. It calls for 8gal still need more after 12gal? #2
Are you sure it's not over full? maybe went past the sight glass? Sometimes its tricky to see new oil.
I thought the same thing. But I kept my eye on it. I was doing it at night too. It almost seems like the level is just below the sight glass. I think I'll unscrew the filter and drain some out that way. Then I can screw it back in to stop the flow.
Yep that's what it was. So clear never even saw it go past the fill line.
   / changed hydraulic/trans fluid. It calls for 8gal still need more after 12gal? #5
wow...good job MFRED
thanks but what is mfred mean?
   / changed hydraulic/trans fluid. It calls for 8gal still need more after 12gal? #7
I think wb19 was referring to MFRED's correct diagnosis in the second post above...:)thumbsup:)
I almost had the same issue- the NAPA tractor fluid I got for my 50-hr service is sorta tea-colored, but he TSC fluid I got for the 250-hr service is darn near crystal clear! Makes it very hard to spot in the sight glass if it's really full.
Seems like I saw a post once about adding something to give the fluid a bit of color....ATF?
   / changed hydraulic/trans fluid. It calls for 8gal still need more after 12gal? #8
I'm guilty of the same thing.
The fluid for my Massey is so clear that I didn't see it go past the sight glass. Had to drain some out.
adding tint to it would help a bunch. hum ATF=RED that's pretty easy to see.....hummmm
Thanks I hate those stupid mistakes. I thought about not even posting this until i had a chance to look at it to see if I over filled it but I got bored at work LOL
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
