Changed Hydraulic Hose. Now only Reverse No Forward.
   / Changed Hydraulic Hose. Now only Reverse No Forward. #1
Axl2011
East Liverpool, Ohio
John Deere 300B
Tractor is a 1970's John Deere 300B.
So a hydraulic line underneath the tractor had a pinhole and was spraying fluid out. I replaced the line and bought hydraulic fluid. Replaced the line and filled up fluid. After repairing that I started up the tractor and the backhoe was working fine. When I went to move forward it feels like it goes in gear then the tires move slightly but then will not move but backing up works good. What could have happened???
   / Changed Hydraulic Hose. Now only Reverse No Forward. #2
I doubt the hose replacement has anything to do with the problem. I suspect the reverser linkage is not totally engaging forward.
   / Changed Hydraulic Hose. Now only Reverse No Forward. #3
I'm thinking possible air trapped somewhere. I had that on my loader with a hydrostat and I realize it's probably totally different. Trouble cleared itself in the course of trying to take pressure readings.
   / Changed Hydraulic Hose. Now only Reverse No Forward. #4
How much oil did you lose and how long did you run it when it was low on oil?
I dont think because when I put it in forward the tired move slightly but goes nowhere like no power
How would I bleed the air? I thought they self bleed through cylinders?
I was only on for maybe a minute when I realized the line was spraying and shut it right off.
   / Changed Hydraulic Hose. Now only Reverse No Forward. #8
I don't know how complex hydraulic systems work. I just got lucky.
I dont know either but you must have been correct! I had my dad come over to try and help me figure it out and when i went to show him it went forward. Now that is fixed but my radiator is cracked. Got to love how these things go. Haha
   / Changed Hydraulic Hose. Now only Reverse No Forward. #10
always something, that's my way of life
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
MURRAY 22" GAS PUSH MOWER (A51248)
MURRAY 22" GAS...
