Rear Finish Mower Change Oil in Rear Finish Mower
   / Change Oil in Rear Finish Mower #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I have a Land Pride FDR2584 rear finish mower. I have maybe 400 hours on it of medium duty use.
In my operators manual there is no mention of changing oil but for some reason I have penciled in to change oil at 200 hours. Does it need to be changed?
I was going to change it today but how in the world would a guy remove the oil as there isn't any plug below the oil level plug. I am asking if there is a plug underneath that I can't readily find. I considered sucking oil out somehow but don't know if that would be good enough. I could tip the mower upside down but risk damage knowing my luck.
Any ideas,
Thanks.
   / Change Oil in Rear Finish Mower #2
Ive got an AT2572 that I bought 20 years ago no telling how many hours on it, never have changed the gearbox oil.
   / Change Oil in Rear Finish Mower #3
I've got a 35 year old King Kutter brush cutter running the original synthetic gear oil it came with.
   / Change Oil in Rear Finish Mower #4
I've got a Phoenix 7' finish mower with about the same hours as yours, and the only way I could find to change the gear oil, was to suck out the old stuff and replace it.
In theory, you shouldn't have to replace it since it's not exposed to the air, combustion, etc. It's a sealed unit, so no dirt can intrude into the chamber. But I wanted to change mine anyway.
Just be sure you get the right weight oil for your machine.
   / Change Oil in Rear Finish Mower #5
I change the gear oil in my gear boxes on a regular basis. They are not cheap to replace.
I generally run the implement for an hour or so, then use a large syringe and tubing to get the oil out and replace with synthetic.
That said, most gear box failures are the result of failed seals and subsequent destruction of the gear box.
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2011 TRAIL KING LOWBOY TRAILER (A51243)
2011 TRAIL KING...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
2019 TAKEUCHI TB290 EXCAVATOR (A51242)
2019 TAKEUCHI...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2014 Fiat 500L Hatchback Sedan (A50324)
2014 Fiat 500L...
