Change oil, filter, both or neither?
   / Change oil, filter, both or neither? #1
orezok
Elite Member
Mojave Desert, CA
Kubota B7800
I was servicing the B7800 this past weekend and I noticed that the transmission oil filler plug was off and laying beside the filler hole. It appears that one of the T&T hosed hooked it and popped it out. Here's the dilemma. The plug was still laying on the flat area next to the filler hole (see pic) which is about 4"x6". It could not have stayed there long if the tractor was working because it would have easily bounced off from any movement. I took a clean rag and wiped the horizontal area which would have been under the lip of the plug. Totally clean. I then wiped the inside of the filler hole and again totally clean. Not a speck of grit or even dust.
I'm guessing that the plug was popped out as I shut down the tractor and lowered the box blade.
Would you change the oil, filters, both or just put the plug back in and consider yourself lucky?.
   / Change oil, filter, both or neither? #2
I think I would consider myself lucky, then reroute the two hoses right behind the plug... Do you have any little ones that might have been playing with Daddy's tractor?
   / Change oil, filter, both or neither? #3
If it were mine I would just put the cap back on and use it.
I would also move or tie back the TNT hoses so it didn't happen again
   / Change oil, filter, both or neither? #4
Like I tell my kids, there's Big Problems and there's Little Problems. That was a Little Problem. Remedy the situation (tie back the hoses?) and forget about it.
   / Change oil, filter, both or neither? #5
What an Achilles heel! Isn't there a way to secure the cap? I can't believe it just sits in the hole...
I think what happened is that I was doing some precision landscape grading. I took off the quick disconnects to gain greater control of the box blade (the slop in the quick disconnects allows about an inch of additional uncontrolled movement at the back blade. This "lengthened" the hoses about 2.5" and they dropped behind the plug. The plug is quite deep and has two O rings to seal it and usually takes a significant effort to remove. I'll just tie up the hoses for now until I reinstall the quick disconnects.
And no the "little ones" left the roost about 15 years ago and fortunately have not asked to return (yet)!
Thanks for your replies.
   / Change oil, filter, both or neither? #7
No need to change oil or filters unless you suspect someone might have vandalized your equipment by pouring some kind of substance into the hole.
I have a padlock on my hood, fuel tank and hydraulic reservoirs to help keep them from being vandalized.
   / Change oil, filter, both or neither? #8
could an airvent be clogged and preasure popped it off?
   / Change oil, filter, both or neither? #9
There is a possibility the breather, located an the front of the rockshaft lift housing is plugged up. This is a rubber hose shaped like a goose's neck. If it gets stopped up it will allow pressure to build up and blow out the fill plug. It"s a good idea to check the breather tube periodicly to insure they do not plug up.
I have had dirt dobbers plug up the breather on my tractor.
Thanks, I'll check it this weekend, but I'm pretty sure it's the hoses catching it.
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
CAT Skid Steer (A50322)
CAT Skid Steer...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
20X30 ALL-STEEL CARPORT W/ ENCLOSED SIDEWALLS (A53843)
20X30 ALL-STEEL...
