Change of mind
   / Change of mind #11
Watch his other videos. Hearty dude. He's probably 32 years old, but hearty. ;)
   / Change of mind #12
I thought that I was hearty when I was 32 also, but not after watching that video. 🥶
I have the same complaint as the OP. That little diskette icon sort of works but you need to completely exit the thread to use it.
   / Change of mind #13
If you decide not to post something, on a PC, just do CONTROL+A to select all and hit the DELETE key. All done.
On a Mac or iPad, just hit CMD+A to select all and hit the DELETE key. All done.
Don't know how the phone works. I rarely use TBN on a phone.
Hope that helps.
   / Change of mind #14
Hope that helps.
But what if you post something then further research finds an answer and you want to go back a while later and delete the entire post?
Is it different for different sections of the forum?
I posted a question, found the answer a bit later, came back and did not see the Delete on the "Report Edit" line.
So I edited the heck out of it.
   / Change of mind #15
You should have a delete button right next to the edit, as in my screenshot above.
   / Change of mind #16
Not sure what you're asking.
   / Change of mind #17
I believe that he asked how to delete a post, hence my reply above. Until that reply, I didn't realize that we can still edit posts after 24 hours have past. OR in the case above, after 41 days.
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2015 CATERPILLAR...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
MOBILE BBQ GRILL (A52708)
MOBILE BBQ GRILL...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
