pierrepicco
Hi Everyone. I'm new to this forum. Let me introduce myself. My wife and I are running a small riding center, in Belgium, for children and handicapped people.
We have an LB1914 with FEL. We have approximately 4 acres, which quite big for Belgium (much more inhabitants per square meter than in the States!).
The LB1914 has now 250 hours. I'm very satisfied with the tractor and it has been running flawless so far. Now, I'm considering to change it for a CK20 HST because I'm tired of changing gears when running back/forth with the FEL. Also, the LB has some drawbacks that the CK doesn't.
(I'm going to post a complete review in the "review" section.)
So, my questions:
Thank you very much for your help!
So, my questions:
Do you consider the HST a good choice to work with a FEL in term of easyness and reliability ?
On the LB1914, switching between Hi/Lo range gear is often difficult (need to clutch several time before being able to engage). Does that issue exist with the CK20 ?
I'm able to draw a 3.5T trailer in 8th, even in slight slopes with the LB. Will the CK HST be able to do that or is there a loss of power due to the HST ?
Any other comment on the CK20 (pros/cons) ?
