Oil & Fuel Change Hydraulic Oil Filter With Full Reservoir?
   / Change Hydraulic Oil Filter With Full Reservoir? #1
JonDeere
Kent, WA
John Deere 750
On my 1987 JD750 with 4WD, can I change the hydraulic oil filter (JD part number RE27284) with the reservoir full? Or will the hydraulic fluid all drain out once I unscrew the filter?
   / Change Hydraulic Oil Filter With Full Reservoir? #2
Not sure but if the filter is below the oil you can hook up a vacuum cleaner to the reservoir and do it that way. The vacuum will keep the oil from coming out. Just make sure it's on suck and not blow (well that sounds just wrong :) ),
Buddy of mine at work was changing a fitting on the bottom of a 40 gallon tank on a plow truck. He hooked up the shop vac, taped the hose to the fill to keep it in place, turned on the vacuum and then crawled under the truck. He then proceeded to unscrew the 2" suction line that had been dripping around the threads, you can imagine the rest. He said afterwords he couldn't understand why the oil was still dripping when he went underneath to start but carried on anyway. Looked like a drowned rat when he crawled out from under.....Mike
M998 (A55852)
M998 (A55852)
8065 (A55852)
8065 (A55852)
LOT: (8) Wheel Loader Bucket Teeth (A59076)
LOT: (8) Wheel...
More info coming soon! (A56859)
More info coming...
2002 TRAVIS BODY & TRAILER, INC. 48 END DUMP TRAILER (A58214)
2002 TRAVIS BODY &...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
