Change fuel shut off/kill switch cable on Ford 3600
   / Change fuel shut off/kill switch cable on Ford 3600 #1
MikeAC
Pa
'72 Power King Kubota B2710 Ford 3600
I have to change the fuel shut off cable on a Ford 3600. Any suggestions on how to reach the lock nut on the underside of the instrument panel?
I can't figure out how to get a wrench on it even if I remove the cowling , and i'm thinking that trying to cutting it off with my fordom handpiece may be the best option
   / Change fuel shut off/kill switch cable on Ford 3600 #2
What I've done is to pull the wire out (unless it's rusted solid) the cut the cable shell as short as possible. Slip a box end wrench over the cable and onto the retaining nut. Grip, hold, and/or turn the flange on the outside with vise grips. Sometimes they can be difficult.
Using PB blaster i let the retainer nut soak for a month , i then cut the cable and managed to break the nut free and used a 3/4 “ socket on the underside of the panel , and holding that with my right hand i used a vise grip to unscrew the whole rig from the outside
   / Change fuel shut off/kill switch cable on Ford 3600 #4
Sounds familiar.
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2010 JOHN DEERE 8245R LOT IDENTIFIER 216 (A53084)
2010 JOHN DEERE...
2003 Club Car DS Golf Cart (A51694)
2003 Club Car DS...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
