Change fuel filter
   / Change fuel filter #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
Is it necessary to change the fuel filter at the 50 hour service?
   / Change fuel filter #2
I had checked mine and it looked like new at 50 hours. I kept an eye on it, being that I was still learning this new tractor. I did finally change it, with no engine running problems, at the normal 200 hour hyd and hst filter service interval. Even then, it looked clean. 900 plus hours and still running well by changing the fuel filter at 200 hours intervals. So my answer would be no.
   / Change fuel filter #4
I don't change at 50 hrs. 150-200hrs between changes works for me.
   / Change fuel filter #6
If I had a new tractor like that, I would try to follow the maintenance schedule and keep maintenance records. But then again, I'm retired and have nothing much else to do with my time or money than to tinker around with stuff and try to look busy so my wife won't find me more useless things to do. :)
I agree with following the manual, but the problem is the manual. One page says to change the fuel filter at 50 hours, another page says it's not needed till 200 hours.
   / Change fuel filter #8
oh, yep you're correct. 200 hrs, my misteake.
   / Change fuel filter #9
If you have a see thru type filter, then change it when it shows some contamination, either dirt or water or if the engine starts to stall or run slower. Otherwise follow the OEM recommendations for all service requirements.
   / Change fuel filter #10
Fuel filters get changed once a year on all my machines. Most of the time I'm well under the hours stated by the book.
2025 John Deere 3025E (A50120)
2025 John Deere...
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
2011 BMW 550i GT Sedan (A50324)
2011 BMW 550i GT...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
Shulte XH-1500 (A50121)
Shulte XH-1500...
