Change B2910 Trans Filter w/o Draining Fluid?
   / Change B2910 Trans Filter w/o Draining Fluid? #1
clarksvilleal
Bronze Member
I just changed the transmission fluid on my B2910 and changed the transmission filter on the left side of the tractor (left side when in seat facing front, that is). However I have just learned that there is another transmission filter on the right side of the tractor. I did not change that one - the dealer I got the new filter and Super UDT did not tell me there was a second filter and so did not offer to sell the other one to me.
I do not want to drain the transmission again just to replace the other filter. So, can I remove the right side filter without draining the transmission again, or will the fluid all start freely flowing out if I do that? I guess I could catch it in a pan and put it back in if that happens, but I don't like to put fluid back in that has drained out of a transmission even if it was recently replaced for fear of introducing contaminants into the trans and hydraulic system.
   / Change B2910 Trans Filter w/o Draining Fluid? #2
Remove the hydraulic/transmission oil cap.
Attach the hose from a shop vac to the hole (helper or ducktape helps).
Turn on vac.
Remove filters or drain plugs, etc. As needed.
Marvel at no oil spilling because of the suction.
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 7FGCU25 LP...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Electric Mobility Scooter (A51694)
Electric Mobility...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
