Doc_Bob said:Who makes the "gold" coolant? What is the brand name?
Bob
Motorcraft Gold
Diesel additive
Bob
Bob_Young said:What with the stability of ethylene-glycol and the difficulty in disposing of used anti-freeze, does it make sense to periodically add the additives (pump lubricant and corrosion inhibitors) but NOT change the anti-freeze? Could you combine this approach with a periodic cooling system drain and flush followed by refill using the OLD antifreeze solution and meet the cooling system's needs without ever doing an anti-freeze change?
SteveInMD said:I only said I use FW-16 in my tractor. I never said I use it with gold antifreeze, or that I use more than I'm supposed to.
DieselMonk said:Maybe... here is something else to think about tho: I have a VW TDI and that has some pink antifreeze in it... no special diesel antifreeze.
Bob_Young said:What with the stability of ethylene-glycol and the difficulty in disposing of used anti-freeze, Bob
