Challenger mt 275 or MF 1440????
   / Challenger mt 275 or MF 1440???? #1
cormier
New Brunswick Canada
Challenger MT275
When checking the hydraulic oil level does the tractor need to be running or stopped on the Challenger mt 275 or MF 1440??? Its the same tractor that's why i am asking for both. I don't have a service manual to look it up.
Thanks
   / Challenger mt 275 or MF 1440???? #2
Can't say for sure on your particular tractor. However, in every tractor I've ever owned, I always check with engine off and rams collapsed. (IE for example loader fully on the ground if you have one) generally speaking, I liked to check all the fluids before I ever start the tractor up for the day. That includes engine oil, engine coolant, fuel supply, hydraulic fluid, transmission fluid if it is seperate from the hydraulic fluid, and so on and so forth. Lot less chance of running low on something and ruining an engine or transmission.
   / Challenger mt 275 or MF 1440???? #3
I have the MT285b, I check with the hydraulics in, power off, and like to see over half up the sight glass on the rear end.
Kubota MX5400 (A57148)
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
30in Forks and Frame Mini Skid Steer Attachment (A56857)
30in Forks and...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
2012 WESTERN STAR  4900 SB INOPERABLE (A58214)
2012 WESTERN STAR...
