Chainsawing trees partially submerged...
   / Chainsawing trees partially submerged... #21
Youare said:
I have cut stuff that has been in the water and like everyone else said the saw chain is a very good water slinger. If you are worried about getting bar and cahin oil in the water for your in the water cuts use vegetable oil instead.
Randy
You can even buy biodegradable bar oil but I bet it will be hard to find. I like the veggie oil idea because at least you'll have some lube!
When you are done, I would drain what is left out and run some regular bar oil through the saw. I can really gum things up over time if left in there.
Ken
Mission accomplished. My wife and I went down there today and completed the job. Talk about rooster tailing! Wow. Awesome!
I took everyone's advice, took my wife as a safety observer in case I whacked my leg or was drug under. The water is high right now, we've had a lot of rain. I intentionally did it now instead of later, because the current/depth combo took my logs away and saved me the hassle of dragging them out after cutting. I had a rope tied around my waist tied off to the Mule (Kawasaki type) in case something happened, the wife could ease back and pull me out:eek:
It was uneventful though...all went well.
Podunk
   / Chainsawing trees partially submerged... #23
Podunk
Good for you Podunk;
Glad it was "uneventful", and thanks for this follow-up post.
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
49" X 58" TRAILER TAILGATE (A54756)
49" X 58" TRAILER...
CLUBCAR GAS GOLF CART (A54756)
CLUBCAR GAS GOLF...
2017 CATERPILLAR 299D2 SKID STEER (A52705)
2017 CATERPILLAR...
UNUSED XSTAR 101" X 25' BRIDGE PLATFORM (A54756)
UNUSED XSTAR 101"...
2003 FREIGHTLINER BUISNESS CLASS M2 SPREADER TRK (A54756)
2003 FREIGHTLINER...
