Chainsaw won't re-start when Hot
   / Chainsaw won't re-start when Hot
Update:
I finally took the time this weekend to go through this saw. I cleaned the carb. It had a pretty gummed up needle valve. I also replaced the fuel line while I had it apart and replaced the gasket between the carb and the cylinder with red RTV. It runs great now: Starts on the first few pulls and keeps running even after it gets hot.
I think the culprit was the gummed up needle valve, but it's hard to say since I did the three things together. I inspected the old fuel line and didn't see any holes. The carb gasket wasn't even too bad. It had a few small rust stains on it, and I figured that while I had the saw that far apart, I might as well do whatever I can.
Edit: I forgot to mention that the total bill was just over a dollar for the fuel line. Everything else was done with stuff I had on the shelf.
   / Chainsaw won't re-start when Hot #22
Good to hear! That gummed up valve could allow gas to continue to flow into the carb and flood it so that is most likely your culprit, nice cheap fix.
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
2025 AGT MX-CRT23 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attach... (A59225)
2025 AGT MX-CRT23...
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2021 Ford F-250...
