Chainsaw scabbard on box blade
   / Chainsaw scabbard on box blade #11
+1 on reluctant to mount the case concept -- I have the STIHL case that looks a little different but the same concept with everything plastic. I had it mounted in the carryall for a while and it tore the plastic and came loose. Now I stick with scabbards made from pieces of vinyl deck board and have not had any issues. I also have a hole drilled in it to fit the "scrench" and a cup hook to hold extra chains
   / Chainsaw scabbard on box blade #12
my plan is to weld up a frame from angle in which it will sit with, say, a stout bungee or two as a hold down ...much the way a battery sometimes is mounted...I can/may even form a metal hold-down as per battery mounting. I like the fact that it will also hold tool/oil/ and "motomix" as well as my sharpener and an extra bar and chain (best cure for a pinched bar and chain, I have found is to remove pinched bar and chain and mount spare)
   / Chainsaw scabbard on box blade #13
JoeL4330,
Good idea on having a spare bar and chain to remove a pinched bar.
Have you actually put all of the extra things you mentioned in the carrying case and snapped the lid shut?
   / Chainsaw scabbard on box blade #14
yes, for my 021 ...my 031 has a humonguous bar;
yes, I wish I could take credit for the backup bar & chain idea, but it's pretty old-school ...good use for a worn-out bar and over-the-hill chain
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A55315)
1995 Ford F-250...
Eagle Weathervane (A55853)
Eagle Weathervane...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
7021 (A55851)
7021 (A55851)
