chainsaw problems
   / chainsaw problems #11
Dutch445 said:
yea, ditto on the muffler, if they get carboned over the
motor can't breathe, and power etc goes away.
it may have a small screen that can be cleaned.. or easily
replaced... worth looking at for sure..
As others have said, check the spark arrester screen on the muffler. I usually remove them altogether.
   / chainsaw problems
I took the muffler off this morning. I noticed a lot of carbon inside. I have sprayed the engine with wd40 a few times, drained it, & attempted to start it. It seems as if a lot of carbon is coming out of the engine. It sounds as if I am making progress, but it isn't running yet.
   / chainsaw problems #13
Twodogs,
Take it to your local chainsaw dealer. It sounds like it's running too rich and needs to have the carb adjusted anyway. If your local shop is any good, they'll adjust the carb while your standing there, and hand it back to you no charge.
If it won't start, then they'll probably ask you to leave it and you'll probably get charged for some work, as you'd expect.
   / chainsaw problems
I have spent enough time on it, to no avail. I think your advice is good. By the way - I like the quote by TR.
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
CFG Industrail MX15RX (A53317)
CFG Industrail...
UNITED 5' BOX BLADE (A52708)
UNITED 5' BOX...
SAKAI SV414D SMOOTH DRUM ROLLER (A52709)
SAKAI SV414D...
