Chainsaw, fuel problems, inexperience......
   / Chainsaw, fuel problems, inexperience...... #1
Mith
Veteran Member
I got this chainsaw with scored barrel and piston. It is all fixed up and has compression with new rings and piston.
The problem is;
I can start it by putting fuel in through the spark plug hole but when the fuel in there runs out it stalls. It wont suck fuel up on its own. I have tried doing open carb surgery but cleaning the passages didnt help.
Whats up with it? Really getting annoying now, I hate small fiddly things that dont work!
Thanks for any help, very much appreciated.
Ooo, forgot to add, it has worked since i did the piston ect replace but it was a PITA to start the first time. I tried to start it the next day and no go.
   / Chainsaw, fuel problems, inexperience...... #2
the intake line is in the fuel tank on most U.S. chain saws, you need to make a hook tool, and fish the fuel line out of the tank, and put a new filter, or end on the line.
   / Chainsaw, fuel problems, inexperience...... #3
What kind of saw do you have? I also had the same problem after rebuilding a Jonsehred. I tried everything! I finally bought a new carb and it fixed it. When talking with a saw mechanic he said the carb is wore out and caused the saw to lean out and score the piston and cylinder. HMM makes since to me.
Rob
thanks for the ideas
i will fish out the filter and clean ect, but it did run, so it used to get fuel
the saw is a stihl, when i got it it was basically unused, still got the paint on its first bar, the chain is origional and still sharp.
I cant think the carb is worn out therefore.
If the mix is real lean would it stop fuel getting to the engine even when choked? how do i set the mix ratio on a engine that wont start
thanks
   / Chainsaw, fuel problems, inexperience...... #5
Could this be related to reed valves??
Egon
if I knew what they were I may be able to answer /forums/images/graemlins/confused.gif
sorry dont have a clue man /forums/images/graemlins/confused.gif
   / Chainsaw, fuel problems, inexperience...... #7
Mith:
They should be the last insert before the crankcase. They are just plates that block the exhaust from the carburator. Lots of different styles.
Egon
how do i check/adjust or whatever them?
would they affect the engine in this way?
sounds good
thanks
cant really visualise them, but i only know the basics about 2 stroke
   / Chainsaw, fuel problems, inexperience...... #9
Really can't help with the troubleshooting on them Mith. Just know I cranked an outboard for hours before the lightbulb got a faint glimmer. Think I installed a carb kit and all was well.
Egon
ok thanks, ill have to look into it
cheers
John Deere 4455 (A50120)
John Deere 4455...
2018 FORD F-150 XL CREW CAB (A51406)
2018 FORD F-150 XL...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
2011 Volvo Semi Truck (NOT RUNNING)(TITLE) (A50774)
2011 Volvo Semi...
