chainsaw decision time
   / chainsaw decision time #31
If I had 6 story, 30", 80 year old pines, I would be trying to sell them. Those would be old growth, tight ring pines that are worth some money. May just be regional and based on demand but as stated they are worth more than wood stove wood.
MarkV
   / chainsaw decision time #32
I can tell you what NOT to buy..... When I first started burning wood, I borrowed a brand new Mccolloch and cut 6 cord with it..... I owe the man a new saw.
I replaced it with a Husky 3?? something, the smallest saw in the professional line. Lotsa metal, starts every time, spins faster than a gogo dancer on steroids, and chews through wood far faster than the cheaper saws.
Bottom line is spend the money. The flannel totin' woodsmen I asked questions to before making a purchase spoke very highly of Dolmar.
E
now theres an idea for the pines, selling them. who would i contact about this? as far as the saw search goes, the guy with the 036 pro seems to be blowing me off, not getting me the compression numbers, so im going to assume theyre probably not too good. quite a few saws just came up on cl here, but new, the dolmar 5105 and the stihl ms290 are tops on my list. the dolmar is ahead because it is a pro saw, but im going to keep an eye on cl the next few days and see what i find.
shindaiwa 490 350$ new
stihl 036 pro 250$
stihl 026 pro 300$ rebuilt
and some idiot put a used ms290 on asking 450. its used, then sent me a nasty email back when i told him it started at 359 new.
ok, the stihl 036 pro has 120psi. from what ive heard, this saw is tired. anyone have anymore insight on this?
   / chainsaw decision time #35
@ 120psi it is on its last leg. For a used saw, 150+ is okay. New saws run in the 180psi range. Unless you can buy it cheap enough to cover the cost of a jug/piston kit, which is usually around $150-200, I'd probabally stay away from it.
   / chainsaw decision time #36
stihl 036 pro 250$
Put an ad in Craigslist and get a bunch of wierdos or talk to your local govt forestry dep.
If you are up to buying off ebay there is at least one well respected seller there - goes by thechainsawguy.
I stihl think that you should look into an Alaskan and mill it yourself. It's not rocket science, and you still get firewood from the flitches.
   / chainsaw decision time #37
It's not about the saw, it's about the right techniques. I bought a used one (Echo) and cleared about an acre on my land with it, including several White pines over 2 feet in diameter, 80 ft tall (huge) and mixed hardwood, large spruce. I had the pine and spruce sawn up by a portable bandsaw and built my sheds and a lot of my house with the lumber.
After that I cut firewood with the same saw for about 6 years until the plug wire finally broke from the coil. I might get the 80 dollar part for it, even though I bought another Echo. It was just a medium size saw.
The point is you don't need a big saw or even a Stilh, as a homeowner or owner/builder you just need a decent medium size (40-45cc) saw, Mine was an Echo with a 16 inch bar , there are others besides Stlh that have good revs and endurance. I keep it very sharp (most important thing) and use the right techniques. If you don't know them work with somebody for a day that does. You can get in trouble really fast with a big tree and for that reason it's almost better to have a smaller saw, turn it in the cut and go a little slower and think about things. Most of the work is after that monster is on the ground. A 30 inch diameter tree doesn't always do what you think it's going to. Good luck, and there are other brands out there that work great.
   / chainsaw decision time #38
I solely heat my 2200 sq ft house with wood (in Manitoba Canada) and I own an Echo CS-400 w/ 20" bar. This saw has done everything that I've asked of it without a lick of trouble. It starts wonderfully winter or summer. Has a great comfortable feel. I usually cut about 8 cord of wood for the stove each year. This year will be its 3rd year.
I also have an Echo weed trimmer. Same thing. Faultless.
They have a 5 year warranty for consumer use.
   / chainsaw decision time #39
In your price range, try and find a lightly used Husky 257. New 4 or 5 years ago, they were a $500 saw that you should be able to find for $350 tops used. They are a good pro saw with a heavy enough piston and rod to have some grunt when needed. They are at their max with a 20" bar but they come close to that "if I had to have one saw" type saw with a 16" and 20" bar. There was a real nice one on ebay the other night but they pop up now and again.
   / chainsaw decision time #40
Yeah, that's a nice saw. I bought a new one on e-bay for pretty cheap with an 18" bar to replace my other Echo although that one just needs a coil after six or seven years of hard use. The CS -400 is a good value and cuts like a screaming banshee with a sharp chain. The point is there are other good modern saws, light weight, durable with good revs out there besides the Stilh, nothing against them either, just that it's not the only game in town like some people think.
Dewalt D28499 7/9" Angle Grinder/Sander (A59076)
Dewalt D28499 7/9"...
Meyer 8.5' Snow Plow (A55272)
Meyer 8.5' Snow...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
Toro Groundsmaster 4000D 11ft Multi-Deck Commercial Mower (A56857)
Toro Groundsmaster...
24in Bucket Mini Excavator Attachment (A56857)
24in Bucket Mini...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
