ChainSaw Conversion
   / ChainSaw Conversion
Thanks for the link MossRoad. Gives me some hope.
Jim
   / ChainSaw Conversion #12
Had a boom truck from the Asplund Tree Service in my yard clearing branches from around the powerlines. The chainsaw the boom man had was hydro powered.
   / ChainSaw Conversion #13
Yeah, that's how I got the idea to search for hydraulic chainsaws under "arborist supplies". Most of the tree trimming trucks for the utilities and their sub-contractors use hydraulic chainsaws in the bucket trucks. They already have the power supply at the bucket(the hydraulics), they have a built in tether in case they drop it(the hydraulic hoses) and there is no centrifical clutch needed like a gas chainsaw. When you let go of the trigger, the chain stops right now and it can't spin because of high idle like a gas saw. It is either on or off.
   / ChainSaw Conversion #14
The forumula for Horsepower is Torque (lb/ft) X RPM Divided by 5252. As an example you want 50 lb/ft of torque at 2000 RPM it requires 19.04 hp. Hope this helps. You can also determine the RPM of a hydraulic motor by knowing that there are 231 cubic inches in a gallon. If you have 10 gpm per minute going into a hydraulic motor that has 3 cubic inch displacement, you will have 770 rpm.
JLG 15 MVL MANLIFT (A58216)
JLG 15 MVL MANLIFT...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
CAT 930M (A58216)
CAT 930M (A58216)
2018 NISSAN Sentra Sedan (A56859)
2018 NISSAN Sentra...
