Chainsaw Bar oil filling technique
   / Chainsaw Bar oil filling technique #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I take a phillips screwdriver, punch a single hole in the foil cover of the bar oil bottle and use that small hole as my automatic flow control valve.
I use to remove entire foil top and on more than one occasion, had an overflow issue. I then went to using a funnel which gets dirty and doesn't allow you to see the level of oil inside the saw... then one day, the light went off for me.
Punching a small hole (only) in the foil, might take a bit longer to fill, but I have much better control of the flow, no dirty funnels to deal with, much less overspill on saw to deal with. I like the better control of the flow the smaller opening gives me.
I highly doubt I'm the first one to think of this, but I do not recall this tidbit ever mentioned here, so maybe it will help someone like it has me.
Richard
   / Chainsaw Bar oil filling technique #2
I've never had much trouble with spillage, but don't like lugging a gallon jug around. So I bought one of those restaurant-style ketchup squeeze bottles and take that. Usually I just unscrew the top and pour, but it would be just as easy to use the spout.
Pete
   / Chainsaw Bar oil filling technique #3
" I highly doubt I'm the first one to think of this,"
Here's one dummy that hasn't.
Egon
   / Chainsaw Bar oil filling technique #4
I use a cleaned out "Downey" fabric softner container, holds about a half gallon and has the no drip cap with a pouring tongue to get it in the opening.
   / Chainsaw Bar oil filling technique #5
I have used the empty maple syrup jugs before (the squeeze ones with the pull out spout.) I don't use them much anymore, I guess I have the pouring technique down better!
   / Chainsaw Bar oil filling technique #6
I tried this with other things but quit after a couple of the foil seals decided to come off while I was pouring and made a big mess.
   / Chainsaw Bar oil filling technique #7
In the saws that I do operate now I have no problem pouring oil from a gallon jug into the oil tank. I have found that any saw you have to turn on it's side to fill is easier than the saws I had where the fill holes were located on the top.
I did see a neat dispencer unit at the local industrial supply house, it had an adjustable spout that came off the side and a handle opposite the spout for pouring. As you twist the spout it goes from off to open in a graduated fashion. It was made of heavy plastic and came in different volume capaticies.
I still like the gallon jugs, no transfering oil from one container to the other or forgetting to fill the jug in the morning. /w3tcompact/icons/smile.gif
Randy
   / Chainsaw Bar oil filling technique #8
Did they quit making drygass bottles? Those babys made the perfect funnels for filling chain sawa when the bottom was cut off.
   / Chainsaw Bar oil filling technique #9
My Dad used old dish soap bottles--the ones where the top pushes down to close and pulls up to open--very common. I still use the same one he used to take out with him. Good control and seals good enough to be thrown in the back of the truck.
   / Chainsaw Bar oil filling technique #10
We use the old fabric softener/liquid detergent bottle technique. Seems to work great on a number of differt saws. You'll want to find a bottle that has a reasonably small spout however to get the greatest benefit from the technique.
2003 Big Tex 10PI...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
1999 CLEMENT END DUMP (A58214)
1999 CLEMENT END...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
5' MOWER (A52706)
5' MOWER (A52706)
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
