Chainsaw advice
   / Chainsaw advice #42
I think he's talking as a pinch preventative. IE.. using a wedge decreases the need to retrieve from your truck, and use a bowsaw.
soundguy
Since you brought it up, could you please explain the proper use of a wedge? I do understand the concept, just not sure I'd be using it right.
Wedge
   / Chainsaw advice #43
If you haven't bought a saw yet check out the Dolmar 5100S. This is a professional 50cc saw that is a little sports car of a saw. I have had one for a year and really like how it performs. The saw should be in the price range you mentioned.
Any safety gear you purchase with be well worth the cost especially chaps.
Randy
   / Chainsaw advice #44
I would go with a either a Husky or Stihl depending on which one you get the best dealer support. Having a local dealer that does service work and stock parts can make life much easier in the future. If you watch these saws on ebay, in good used condition they sometimes sell for more than they did new.
If you plan on using the saw only a few times per year there consumer grade saws are just fine. If you plan on using the saw one a week or more you ought to look at their pro grade saws. It is really worth it.
   / Chainsaw advice #45
We began heating the house with wood exclusively last year. I was using a 42 cc, 16" Husky prior to that. Since I was going to be cutting much more wood (about 12 cords/year) I upgraded to a Stihl MS310.
I believe it's about the same price as the MS290 but with a bit more power (59cc). I've been very happy with both saws. I really don't think you could go wrong with either one or a Poulan as long as you have a dealer that's close.
   / Chainsaw advice #46
Erik_in_Hoyt said:
Maybe where you are there's only E10 or better.
Up here you have to know where to find it.
E85 is even harder to find.
quote]
So just where do you find it? Some illegal refinery since the feds have mandated that all gas have ethanol.
It sure does ruin boat engines too!!!
Andy
   / Chainsaw advice #47
Where I got that particular piece of advice was from a Stihl dealer/repairman - because ethanol and high detergent gasolines were the 2 biggest $$ makers for him as he put it -- they caused the fuel & oil to separate within about 10 minutes of starting. [/QUOTE said:
The subject of fuel separation in ethanol fuels usually occurs when water get into the fuel. Ethanol absorbs water readily right to the point where it is saturated, then the ethanol/water mixture will separate from the gasoline. Your chainsaw won't run on the ethanol/water mix, and will run badly on the remaining gasoline because the ethanol provides a needed octane boost to the gasoline. A lot of the stories out there about ethanol are simply wrong. Try this: put a cup of mixed ethanol gasoline and 2-stroke oil in a glass jar and seal the cap. Now wait a day. See any change? Now remove the cap and check the fuel after another day. See any change? Ethanol will pull the water vapor right out of the air and looks a bit like skim milk.
Ethanol/gasoline mixes will work very well if you keep the water away from the fuel. Only mix enough fuel to be used in a week or so, and store it in a sealed container.
A far greater risk than ethanol is lending your saw to a neighbor, friend, or, worst of all, to a family member. I can't count the number of borrowed saws I've seen that have been run on straight gas, or a bar oil/gas mixture, or the fuel tank filled with bar oil. The bar oil just causes a temporary problem, the straight gas gets very expensive.
   / Chainsaw advice #48
quote]
Andy
The Feds mandated oxygenated fuel in those areas with a pollution problem. MTBE was used for years until it was determined that it polluted the groundwater, so we went back to ethanol.
Big parts of the US are exempt from the law, but the ethanol fuel is gaining. It's up to the states to decide if the stations have to post a notice that ethanol fuel is being sold, and many states don't require that posting.
I agree that boat engines are worst-case: all that water, and ethanol loves water.
   / Chainsaw advice #49
Kansas is not a high pollution area and does not mandate the use of ethanol. They do mandate posting ethanol content on the pumps at stations that sell it.
I like using E10 in the truck in the winter at least every other tank, as 10% ethanol for a $.03 discount per gallon beats $1.89 for a 12 oz bottle of heet in the tank, and the E10 does as good or better a job of "drying" out the fuel system.
   / Chainsaw advice
Thanks all for your advice. Last night I finaly made my purchase and ended up spending way over my budget but after using it I think I made the right choice, I bought the ms-361 pro model with the 18" bar and aggresive chain. As I said I used it last night and holly S___ this thing rips! I was cutting 18" oak pretty much as fast as I could push it, it was awsome! the chips look like wood mulch. Again thanks for all of the advice.:)
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
Enerpac RCS302 30-Ton Low Height Hydraulic Cylinder, 5" Tall (A59076)
Enerpac RCS302...
THREE POINT WYLIE SPRAYER (A58216)
THREE POINT WYLIE...
