Chains: Front vs Rear. Are front Chains bad for tractor
   / Chains: Front vs Rear. Are front Chains bad for tractor #1
PaulP
I have a Bobcat CT450 (rebadged Kioti) compact tractor. 4x4 with cab.
I was inquiring about chains and the selling dealer advised "no way put chains on the front" "you'll tear your tractor apart."
This is not what I've heard from others in fact, many suggested only put the chains on the front for our sometimes icy, slick blacktop roads that I maintain.
What's the ground truth here? Also, what are the best style chain surfaced roads without tearing them up?
Thanks
OK, AFTER POSTING THIS, SEVERAL PREVIOUS DISCUSSIONS APPEARED AT THE BOTTOM AND IT SEEMS THE GENERAL CONSENSUS IS "THERE IS NO AGREEMENT".
THERE ARE BOTH SCHOOLS OF THOUGHT ON WHETHER IT'S GOOD OR BAD. BASED ON THE DISCUSSION, I THINK I'LL ONLY PUT THEM ON THE REAR. STILL NEED SUGGESTION AS TO WHICH STYLE OF CHAIN TO USE THOUGH. (PS: I'M NOT SHOUTING - I JUST WANTED TO EMPHASIZE MY FOLLOW UP).
   / Chains: Front vs Rear. Are front Chains bad for tractor #2
For 15 years I used heavy duty V-bar ladder chains - front & rear on my Ford 1700 4WD. Never caused any damage to the tractor. The only real damage - the difficulty for me to instal.
If you are concerned about damage to your unit - go with rear chains only. Were I to do it again. I get a set of the European style chains for the rear only. V-bar front & rear was FAR MORE than a dramatic traction increase. It bordered on the unbelievable. But they DO give a rough ride.
   / Chains: Front vs Rear. Are front Chains bad for tractor #3
Just a thought. Some small tractors (like mine) don't have enough clearance between the front wheels and other components to accept chains. Even if there seems to be enough clearance, if the chain is loose it could snag a steering component or the frame. Larger tractors don't have this issue.
   / Chains: Front vs Rear. Are front Chains bad for tractor #4
The ONLY chains I would recommend are the Euro type;
Auiline,
Trygg,
OFA's
these style of chains will provide the best traction and ride quality of any conventional style of tire chains.
   / Chains: Front vs Rear. Are front Chains bad for tractor #5
For sure Kenny. The thought of a loose set of chains grabbing something - beyond upsetting. I'm just glad my M6040 doesn't require chains. They were not one of my favorite "add-ons". As heavy as the ladder V-bars were for the smaller Ford 1700 - I can only imagine the weight for my M6040. Actually any good chains are pretty heavy.
   / Chains: Front vs Rear. Are front Chains bad for tractor #6
I have a smaller tractor but all I use is front chains.
Simple 2 link ladder chains. (Actually from a lawn tractor)
Rear chains on my turf tires gives a really ruff ride.
   / Chains: Front vs Rear. Are front Chains bad for tractor #7
My 6040 does need chains on the hilly, rough terrain where I live and I put fronts on this year and the steering difference when plowing is like night and day.
I was warned by a mechanically knowledgeable friend that front chains can put major strain on front end components.
This was when I has the L4630 with R4's. The M has R1's and a stouter front end.
And yes, the rear chains are very heavy [I think they weigh more than me]:laughing:
   / Chains: Front vs Rear. Are front Chains bad for tractor #8
Auiline,
Trygg,
OFA's
View attachment 592513View attachment 592514
I totally agree. Spend the extra and get the Aquiline chains. The Aquiline MPC are a low profine chain. I have v bar ladder chains and wish I had bought these. Ladder chains give a bumpy ride, especially when they're on the front.
Tractor Tire Chains - Aquiline MPC | Free US Shipping
And I run chains on front and rear. My driveway is ice all winter after the first storm so I don't really have a choice if I want to be able to steer.
   / Chains: Front vs Rear. Are front Chains bad for tractor #9
You need a new dealer. Front tire chains will not hurt your tractor. I've used F & R tire chains for decades as have thousands of others.
Ladder style chains are acceptable for use on asphalt or concrete. so long as they do not have studs or V-bars.
I use two link ladder chains on multiple tractors and on asphalt. I do not recommend four link ladder chains for multiple reasons.
Go to tirechains.com and read about the advantages and disadvantages of the various styles.
SDT
   / Chains: Front vs Rear. Are front Chains bad for tractor #10
Thanks
Been running chains front and rear on my DK 35 for years, no issues.
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
