Chains and Protecting the Concrete Floors
   / Chains and Protecting the Concrete Floors
Thanks everyone. Drizler, good idea, not local for me but I'll be taking my tractor back for the 50 hour service and have some hydraulics put on it so I may just go that route.
Paul, Great idea of TSC. They've got a variety plus some rolled rubber mats. I'll take a look.
   / Chains and Protecting the Concrete Floors #13
Used belts from a roll type hay baler are also tough, however narrow enough to have to fasten a couple or more together to get the width you might need.
   / Chains and Protecting the Concrete Floors #14
If you are fussy about the floor use several 2x 10 plank. Much easier to sweep around after the chains drop their collected load of mud.:D
   / Chains and Protecting the Concrete Floors #15
Egon...do you know what lumber costs these days???:eek: ...:D
   / Chains and Protecting the Concrete Floors #16
Sounds like you are fussy about the floor. Go buy the lumber.:D :D
   / Chains and Protecting the Concrete Floors #17
My question is if your worried about the floor of the barn that nobody can see then what about the drive that everybody can see? Chains make pits gouges scratches all over the drive. I just had my drive done all 9600 sqft of it. I'm hoping I don't have o have chains..... cause I think the boss will freak if I scratch it up.
Not sure if you're directing this to me or not. Anyway if so: I'm concerned about the cement floor to my garage which is where the tractor is kept. Not really concerned about appearance, but about damaging the floor. My road is gravel, not blacktop, so not concerned about chain marks on the gravel. You certainly bring up something very important for me to think about though. My drive is very steep and if I did pave it then I would have issues running chains on it to clear up the snow, so it is better and cheaper keeping is gravel than paving it. thanks for the thought.
   / Chains and Protecting the Concrete Floors #19
The couple pieces of scrap 1/2" plywood I put under my tractor have held up quite well for 3 or 4 years now. I've put v-bar chains (basically, studded chains) on my rear tires for the winter. Snow and ice tracked in by the tractor have not caused problems with the plywood. It was cheap (free, since I had them lying around) and has proven durable. I leave them down year round, but only have the chains on the tractor in the winter. Tractor is a TC 33D with filled rear tires.
John_Mc
   / Chains and Protecting the Concrete Floors #20
I park on a couple of pieces of 1/4 luaun. Still looks good after 4 years. Of course I don't have chains either!
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2017 Ford F550 (A55973)
2017 Ford F550...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
Towable spreader (A55973)
Towable spreader...
