Chain
/ Chain #1
Ivan49
Lake City Mi
Kubota L 3301
I have some conveyor chain that is 2050 chain. What sprocket do I use for this chain? Will a 50 P sprocket work? Thanks Ivan
/ Chain #2
It would deped on two things.
1. Wether or not the chain has s rollers of r rollers. S are a standard size roller and R are an oersized roller.
2. The size of the sprocket you have.
2050 chain has the same dimensions as a 50 chain excet it is a double pitch. chich means all dimensions are the same except it only has half as many rollers. If it has s rollers, it will work on larger 50 sprockets. Because the pitch is doubled, you will only catch every other tooth on the sprocket. It doesn't work well with smaller sprockets. I think it is 30 tooth and larger can use a standard #50 sprocket. If the chain has the R oversized rollers, then you would need a special sprocket.
2018 CATERPILLAR CB10 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
TRUCK RAMP (A64556)
TRUCK RAMP (A64556)
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2015 Polaris Sportsman 570 AWD ATV (A64557)
2015 Polaris...
