Chain
   / Chain #1
Ivan49
Lake City Mi
Kubota L 3301
I have some conveyor chain that is 2050 chain. What sprocket do I use for this chain? Will a 50 P sprocket work? Thanks Ivan
   / Chain #2
It would deped on two things.
1. Wether or not the chain has s rollers of r rollers. S are a standard size roller and R are an oersized roller.
2. The size of the sprocket you have.
2050 chain has the same dimensions as a 50 chain excet it is a double pitch. chich means all dimensions are the same except it only has half as many rollers. If it has s rollers, it will work on larger 50 sprockets. Because the pitch is doubled, you will only catch every other tooth on the sprocket. It doesn't work well with smaller sprockets. I think it is 30 tooth and larger can use a standard #50 sprocket. If the chain has the R oversized rollers, then you would need a special sprocket.
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2006 Pierce Fire Truck (A51692)
2006 Pierce Fire...
Tafe 45DI (A50123)
Tafe 45DI (A50123)
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
