chain saws on a stick comparison
   / chain saws on a stick comparison #1
BudinTenn
Wondering if anyone here has any experience with the different brands of pruning chains saws. Big difference in the price of the Poulan at Lowes vs the Echo, Stihl & Husqvarna brands. The higher priced units are obviously more heavy duty. Are they worth the higher price? I would expect I'll use one a few hours a year. Thanks
   / chain saws on a stick comparison #2
I have the Poulan Pro -- I wouldn't recommend it. Cuts OK, but so tempermental and hard to start, you kinda avoid using it...
   / chain saws on a stick comparison #3
I've got a pruning saw attachment for my trimmer (a 4-stroke Toro). Works OK, but still a bit of a nuisance - I'd rather get a ladder and use my Black and Decker 18V saw in most cases and if I can't reach with that a pole saw won't help so I resort to a rope saw.
   / chain saws on a stick comparison #4
I bought a Poulan Pro combo pack that had the string trimmer and pole saw together. Mine starts and runs fine. The string trimmer works great. I do not recall my model # and it is outside right now. I can find it tomorrow if I remember. :)
However, I have some negative comments about the pole saw.
First, the chain bar can tilt on its bolt. There is only one bolt and I constantly have to tighten it. When it tilts, it pries on the plastic shroud. Sooner or later it is going to break.
Second, if I leave it sit on the floor the bar/chain oil tends to drain out of the tank and make a puddle on the floor. I have not found a good storage angle for it.
Third, it is a heavy @##$%@ piece of equipment to hold over your head for any amount of time. You will get sore.
Fourth, it bogs the engine down easily. I do not think it has quite enough power to cut 8" limbs. It is fine for pruning.
The positives of the unit are it changes between the string trimmer and pole saw very, very easily. Just loosen a knob, bush in a thumb button, remove the attachment, slide another one it until the thumb button clicks, tighten the knob and off you go. It has a nice support on the housing so you can set it down to fuel it and it won't tip over on its side. To start it, you just flip the choke lever to start and pull the cord. It fires up and the choke stays engaged. You let it warm up and as you hit the trigger, the choke comes off. Nice feature compared to my older manual choke equipment. The unit has a very nice reach. I am 6' tall and can trim stuff up around 11' without lifting too far. A bit higher if I reach above my chest.
Overall, I give it about 7.5 out of 10. It needs a bit more power for the saw and a sturdier mount for the chain bar.
   / chain saws on a stick comparison #5
I have a Poulan that I bought at Lowe's. I would have to go out to the garage to see what model as it has been awhile since I used it.
Being a Stihl kind of guy, I really did not want to buy a Poulan but I did not think I would have enough use to justify the 500 or so for a Stihl or something similar.
I can live with the tempermental engine part but the first time I used it, the head spun around as soon as I tried to put a little cutting pressure on a branch. No way I could tighten it up on the shaft enough to stop it from turning so I drilled a hole and tapped a hole for a machine screw. That worked but I really should have just returned it for a refund.
   / chain saws on a stick comparison #6
The higher priced units are obviously more heavy duty. Are they worth the higher price? YES, absolutely.I would expect I'll use one a few hours a year. Thanks Even a few hours a year can and probably will become more frequent when you have a quality machine to do the work.
   / chain saws on a stick comparison #7
I have used the Stihl Kombi system extensively, with the chainsaw attachment. It works great! You can also attach other implements to the same motor if that would help. The fact that it breaks down into two short lengths helps in transporting it on a tractor or 4-wheeler in brush, or in the trunk of a car. My only gripe is that I go thru many blades as they dull rather quickly, but this is inherent (I would assume) in all brands, since the chains are short. It's also easy to touch the ground when trimming trees low to the ground and this reduces chain life. If you use one as much as I do (mainly trimming trees or limbs overhanging roads) you should learn to sharpen the chains yourself or be prepared to buy multiple chains. Sthil products are top notch.
   / chain saws on a stick comparison #8
I've been pretty happy with my $100 electric one. Don't use it much but it gets the job done, no starting problems:) If I need it remote from power I simply take a small generator. All my overhead limb trimming has been along a driveway so the FEL with the generator sitting in it works nicely. I've even run it off the 2kW invertor installed in my truck. Can't recall the name but I see the same one sold under several names.
   / chain saws on a stick comparison #9
I have had the Echo PPT 260 for about 2 years now and I can offer a few observations about it.
Pros:
* Very well made and sturdy.
* Extension to over 12'? eliminates the ladder in many cases.
* Even though it may sit for months at a time it usually starts right up.
* Quite powerful. Not only is it useful for cutting down good size limbs it is also very handy at limbing once the branch is on the ground.
Cons:
*It will give you quite a workout because of the leverage involved in holding the pole to where it needs to be to make the cut without getting the bar pinched. Overall its not that heavy but when your holding it overhead for any period of time it is straining.
*Will tend to leak bar oil out of the tank when stored flat on the ground. I have dealt with this by just putting a piece of cardboard underneath it.
*I'm not sure that this is really a negative but it did retail for close to $600 if I remember correctly. I say this because it is a quality built machine that should last a lifetime if maintained properly.
As others have mentioned you get what you pay for. Good luck on your decision.
   / chain saws on a stick comparison #10
I have a Stihl and it is awesome, I use it pretty much for everything.
2009 Utility Trailer Mfr. 4000DX 53ft. T/A Dry Van Trailer (A55852)
2009 Utility...
2012 Chevrolet Silverado 3500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
PALLET OF MERITOR BRAKE SHOES (A55745)
PALLET OF MERITOR...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
EZGO (A50324)
EZGO (A50324)
