Chain saw tossing chain, bought new still do.
   / Chain saw tossing chain, bought new still do. #1
2458n
Poulan 380 being used to cut 20 inch ash tree. The bar it came with was 24 inch and carried a 84 link full chisel chain. The saw ran fine for two hours. Then it threw the chain even though it had been adjusted twice after break in. The links were damaged to the point that the chain could not be pulled through the bar by hand. I was 104 miles from the house so purchased a new chain [3/8 .50] from oregon. New chain lasted 5 minutes and it was off. Was told to replace the roller rim sprocket and I have done so. The bar appears straight. Is there anything to check for before starting again? The saw is used with unknown hours.
   / Chain saw tossing chain, bought new still do. #2
Did you inspect the bar to make sure it is not excessively worn? You can dress the bar if worn if you are skilled with a flat file.
There is also a method where you make sure the bar tip is pressed upwards before tightening.
How To Tighten a Chainsaw Chain
Used a flat file along the flat edges of the saw. Tip alittle worn but my saw guy did not try to sell me a new one so the bar must be usable in his opinion. Was going to eliminate the bar question by buying a bar chain combo off of Amazon. Real estate taxes do the 20th of this month so buying may be done for now. Thank you for your input. Never bunged up the drive links before but managed to do it with these two chains. Tension started off right. Oiler working.
   / Chain saw tossing chain, bought new still do. #4
Is the drive sprocket in good shape?
   / Chain saw tossing chain, bought new still do. #5
Are you sure the chain is tight when it is throwing it?
How big of stuff are you cutting when it throws the chain?
   / Chain saw tossing chain, bought new still do. #6
Is the oiler working?
   / Chain saw tossing chain, bought new still do. #7
Sprocket, bar, oiling, and proper tensioning (when cold) are all that's left.
   / Chain saw tossing chain, bought new still do. #9
Is the drive sprocket in good shape plus the right pitch for bar chain?
   / Chain saw tossing chain, bought new still do. #10
I'm thinking the drive sprocket also. Its about all that remains.
A thought - check the entry slot in the bar - where the chain enters onto the bar immediately after going around the drive sprocket. If its not in good shape the chain will simply "drive itself" off the bar.
UNUSED TOPCAT QUICK ATTACH STUMP GRINDER (A51244)
UNUSED TOPCAT...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
IH 445 Square Baler (A50515)
IH 445 Square...
