Chain Saw Sharpening
   / Chain Saw Sharpening #31
I've tried a couple plunge cuts and the thing wants to bounce hard and that seems dangerous to me, so I don't try it and am very careful to not let the tip hit anything. But, I know it can be done as I've seen it done. I just don't feel comfortable doing it. :)
I really need a new saw, just for safety sake. Mine is an old Sears saw. 18". Cuts great. Light yet powerful enough for me. However, it has no chain brake and a tiny hand guard. And just last week the on/off switch won't turn it off unless you really press it down. Time to look for a newer model with chain brake.
What fun toy can you make with a chainsaw engine? :D
Plunge cuts are pretty dangerous and there's a real skill and art when attempting with a normal bar. The trick is to do the cutting with the nose bottom, not the nose top. A carving bar will work very for notching fence posts since the 'danger area' is much smaller.
You could convert your unsafe saw to a winch, or have it power a small scooter or a big model boat.
I have the HF sharpener, and it's well worth it. It does have a depth gauge but you'll need file the rakers by hand with a flat file and a raker gauge.
   / Chain Saw Sharpening #32
I'm not retired either. But I have a teenage daughter and I don't mind if the young men see me sharpening a chainsaw or cleaning a shotgun. :D
Sounds like a good plan, with two daughters I am picking
up wisdom anywhere:)
   / Chain Saw Sharpening #33
Now that makes sense. I've always hit the top of the nose instead of the bottom. :rolleyes:
   / Chain Saw Sharpening #34
Hey Moss Road, you gotta get a saw with a chain brake man. You can, at certain times or with certain types of cuts actually hold your upper hand in such a way that you press against the back of it so ANY tiny bit of nasty business makes it lock on. I don't think I will ever use my antique Skill no-brake saw again.
When I make plunge cuts I use the bottom of the tip as noted and when it's finally deep enough "push" the tip straight through the log. Always at very high RPM's and I don't think I'd ever do it with a chain that was immediately just sharpened because sometimes they bit a bit harder. I wonder what an expert like Treemonkey would have for advice.
   / Chain Saw Sharpening #35
Ridge ,
Thanks I understand now. No troubles..
   / Chain Saw Sharpening #36
I've heard they make great blenders. A little noisy, but powerfull. Anybody need a margarita or a banana monkey.
Wedge
   / Chain Saw Sharpening #38
   / Chain Saw Sharpening #39
I have been using the harbor freight sharpener for a couple of years and love it for sharpening the teeth. Unfortunately it is not so handy for setting the depth. I started tinkering and found that the depth is every bit as important. That got me thinking.
I live in a pine forest and pine or aspen is all that I ever cut. Could I get away with dropping the depth deeper then the manufacture recommends since I am only cutting soft wood? I am tempted to just try it on my old mcculloch, but I figured I would put the question out there first.
   / Chain Saw Sharpening #40
Most of my cutting experience is/was with hardwoods. Occasionally we'd get a pine lot to clear. Depending on the species of pine, sometimes a deeper depth gauge actually makes things worse and slows cutting down. The wood is too soft to break cleanly and grabs hard akin to getting a saw stuck in a protective leg chap. Try it for your pine and see how it works.
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56436)
Bulk Lot of over...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
