chain saw sharpening
   / chain saw sharpening #31
I also have a oregon sharpener and it is what most "professional" people use.
   / chain saw sharpening #32
I bought a little hand file sharpening kit for 20 bucks or so that works fine for home use. It has the right size round file for my chain, and incorperates a flat file for the rakers. Has some guide lines to help with the angles. Follow the directions and it works. It fixes up a dull chain nicely. I keep a spare chain nice and sharp in case I destroy the one on the saw.
sounds like the kit i bought, I just bought the stihl branded one because non of the other companies listed stihl in their guides, now i know what to look for if i ever need another one.
   / chain saw sharpening #34
I have never had a chain 'ground' in over 40 years of using a chainsaw. My methods are not going to work for every individual, but they work for me. I hand file mine every nearly time I fill with gas, depending on what I'm cutting. This keeps the chain sharp & gives me a break! 2 to 3 strokes on each tooth, same number on each. I file the from right side with my right hand, from the left with my left hand. The main thing is to keep things even. I've never had to file a raker, if a chain is filed properly, the rakers will wear on their own. The Stihl chains I use have the angle mark on them to keep you straight. No vice needed, just a good solid suface and hold the saw under my opposite elbow. Again this won't work for everybody, it takes time to learn & practice to keep a "true" hand.
Just keep your chains sharp! It's easier on both you and your saw! ~~ grnspot110
   / chain saw sharpening #35
Out in the "Woods" it may be hard to find a vise. Out there I usually try to find the right sized log to rest the bar on.:D :D
   / chain saw sharpening #36
grnspot110 said:
I have never had a chain 'ground' in over 40 years of using a chainsaw. My methods are not going to work for every individual, but they work for me. I hand file mine every nearly time I fill with gas, I've never had to file a raker, if a chain is filed properly, the rakers will wear on their own.
[snip]
You read my mind - Ive just been holding my peace. Its not rocket science. I dont sharpen quite that often tho. I just watch for dusting in the shavings or a curve cut. I also spot check the edges on both sides with fingernail at each gasup
larry
   / chain saw sharpening #37
Good day everyone,
I started using an Oregon sharpening Kit (flat and round file ant guides for the files). Now I only use the guide for the rakers. Do not forget to turn your plate around every 3 sharpening sessions and keep good tension on your chain (the cutters will not rock back and forth so much).
Marc
   / chain saw sharpening #38
Greetings..How you sharpen depends on how much you cut. I burn wood and use 3 Stihl Saws weekly. Electric is by far the fastest and easiest.
Thanks..
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
BUNDLE OF 2" X 2" X 22" ANGLE IRON (A54756)
BUNDLE OF 2" X 2"...
HOBBS MODEL-666 6 ROW PEANUT RESHAKER (A54756)
HOBBS MODEL-666 6...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
