Chain Saw recogmendations
   / Chain Saw recogmendations #31
Daryl,
It must be a relatively new feature. On the Stihl site they say
"Concealed inside the bar nose, the sprocket on the STIHL ROLLOMATIC® E-Standard is securely protected against corrosive and abrasive dirt. STIHL guide bars don't need to be greased."
This is in big bold letters.
But under accessories they have the little grease guns for the rollers. I assume they would be for the older saws and at 25 years yours definitely qualifies. My home owners 025C doesn't have any holes to lube the sprocket. I sure hope it lasts half as long as yours.
Phil
   / Chain Saw recogmendations #32
Daryl,
I just salvaged my computer and saw your post about trailer with no lights on them. I run 2 trucks (1 w/trialer and LIGHTS, one Isuzu NPR with caged bed) in a professional Lawncare and Landscping business. As far as product knowledge on equipment, I have worked for two lawn and garden manufacturers in sales and marketing for over twenty years and know alot of factory guys for most major companies. I am new here and try to give unbiased opinions since I have been around and probably used most of this equipment others are posting about. I'm sure people on this post get tired of being told they need a stihl when a Poulan will do the once a year cord of wood just as well.
Samisam /forums/images/graemlins/confused.gif
   / Chain Saw recogmendations #33
samisam:
At least you admit you are "new" here.
The original poster asked for the posters "preference" and my preference is Stihl. That preference is from my "personal hands on experience".
I don't make it a point of being tedious with posts, I don't have the time, nor want to.
I don't really care if you cut your wood with a hacksaw. You want to discuss it, don't do it here. My profile has my e-mail address. Do it privately.
As far as lawncare businesses. I have followed numerous "lawn care" trailers behind pickup trucks with no lights, turn signals or DOT required reflective tape on them. As a professional steel hauler I must adhere to regualtions concerning proper lighting and working turn indicators. You should to. Or should I say, "lawn care professionals".
In closing, I'll mow my own lawn, thank you.
   / Chain Saw recogmendations #34
I have a 50 husky bought during Hurricane Hugo, I also have a Echo weed eater that is the same age 14 yrs. If I had to buy another saw now it would be an echo just for dealer preference. But you cant go wrong with Sthil, Husky or Echo. /forums/images/graemlins/cool.gif
   / Chain Saw recogmendations #35
I own quite a few Husky products primarily due to the quality of the local Husky dealer. That said, I have no info or prejudice against the other brand, but I only own Huskys. I did my last cutting/yard-work in September of last year. My saws, weedwhackers & blower all sat in my shed for six months with gas in the tanks & no fuel preservative. I started all of my garden tools a few saturdays ago. The 372XP chainsaw started right up with two or three pulls. The model 350 didn't start after ten or so pulls. I went to my 12yr old Mod61 Rancher, two pulls and shes going. Then I went over to my 245RX brush cutter ($$) and it started right up. I then went to the 326LX and it took about 20 pulls before it was going. The leaf blower took about twenty pulls before it was started. Okay, I have pattern, the consumer stuff isn't so forgiving as the "pro" equipment. Now I take another try at that 350 chainsaw, twenty more pulls & nothing. I'm getting tired & move to the bigger toys. My Toro tiller with a Honda engine,: it starts right up one the first pull. Now my Honda push mower, well not so good, it took about 10-15 pulls & a lot of choke work. Yes, I left the fuel turned on for both of the Honda engines all winter. Now the 350 again - 10 pulls and I'm off to get the screwdriver so that I will be able to spritz some fuel on the air-filter. I take the cover off, and the air filter is pretty much clogged. I take the filter off & she starts right up.
Just some shared experiences from a tool abuser. /forums/images/graemlins/blush.gif
   / Chain Saw recogmendations #36
I dig chainsaws. They are a terribly useful tool that all home/property owners should have. I am generally a Stihl person. In your (and anyone's) position, please consider the dealer network. You cannot go wrong with Stihl, Husqvarna, Jonsered, Dolmar/Makita. If you deviate into the cheap, more mass-market saws they will fail you. The average cheapy saw (including the Husky 100 series saw) are designed to throw away after 50 hours of use. Truth is, you would be better off buying a used Stihl, Husky, Dolmar/Makita, or Solo than a new Mac, Craftsman, Poulan, etc. Always use good gas, good two-stroke oil, and good bar oil. I personally buy Pro level saws (they are good for me). I do not recommend such a saw for two reasons: expense and useability. With a Pro saw, a twenty inch bar comes standard on a high RPM lightweight saw (for limbing and ground work) whereas a good stump and felling saw is too heavy for all day use. I would recommend something like a Stihl MS260 or MS290, a Dolmar PS540 (Makita DCS540), or a Husky Rancher 55. I think something bigger would probably be overkill and all of these saws will run a 20" 3/8ths just fine. Incidentally, all of their websites list saw weight, horsepower, and displacement. The best saw for long term use will be the lightest in your respective horsepower/displacement group - if you don't use it a lot at one time, wieght isn't as important. Remember that a saw with less HP at a given displacement usually has more torque than one with more HP at that same displacement. This means less opportunity for jams and more opportunity for stump work or bigger bars. You can buy Dolman/Makita and Husky over the web - Stihl you must buy from a real dealer.
Hope this helps, email me if you would like more specifics.
Jon
   / Chain Saw recogmendations #37
My experience is totally Stihl and Husky. I currently have 11 chainsaws, 6 Huskies (261, 357XP, 2-365's, 372XP and 385XP) and 5 Stihls (026, 036, 046, 056 and 066). I'm no logger, but do a lot of cutting, plus, at least according to the missus, I like to collect things /forums/images/graemlins/smile.gif
Of the bunch, the 365 Husky is the one I go to first, all the time; I like it so much I got a second one. For an all-around saw, I can't imagine a better one than the 365. The 036 is close, but the 365 just feels better, for whatever reason. Both of those are in the $500 +/- range, depending on bar length, but, should give a lifetime of use. For occasional use, the "homeowner's series" in either brand should suffice, but, I like the generally lighter weight and higher HP to weight ratio of the "pro series".
Madsen's has the best prices I've found for Huskies; Stihl, I believe, is hurting themselves by keeping sales of their product off the 'Net.
When buying the saw, get proper protective gear and use it. Those things can do major damage in a heartbeat.
   / Chain Saw recogmendations #38
</font><font color="blue" class="small">( Stihl, I believe, is hurting themselves by keeping sales of their product off the 'Net. )</font>
Maybe, but they are supporting their servicing dealer network instead of stabbing them in the back like so many other brands.
Slam
   / Chain Saw recogmendations #39
gonna have to postpone a reply now but want athis on my fav's!! love all 3 of my saws...husky 41 for climbing...sthil ms 290..med to big..and heavy cuttin...and my big daddy with a 4' bar...jonsered 2095 turbo..4 the really big stuff!!!..all r wonderful and have a purpose 4 each!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Chain Saw recogmendations #40
I was speaking strictly from a "want the best bang for my buck" perspective, slammer. You are correct, of course, in that the local dealer, who has to maintain a building, parts supply, people, etc.., needs factory backing, but, too often they (speaking of my local Stihl guy) charge way more than they should for the product.
The 066, admittedly a pretty high dollar item, was $120.00 more at the local shop than at one 50 miles away, the local guy wouldn't budge on the price, so I bought it from the guy 50 miles distant. I can't see how that helped the local guy any. I think the more saws out there, regardless of where they're purchased, the more chances of one needing some work, so, the average guy will take it to the local Sithl/Husky shop to get it worked on, rather than send it back to where he got it. That's what I do with mine, anyway.
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
KING KUTTER SCOOP PAN (A52708)
KING KUTTER SCOOP...
