chain saw help
   / chain saw help #1
deerefan
louisiana
1952 8N, 2005 JD 5103
Well, my 15 year old McCullough (I think that's spelled right) is near the end of it's life. I was looking to buy a husky or stihl but can't really see spending a ton of money for a saw I'll use only once a month for and hour or two. I noticed the box stores sell Poulan, Homelite, Echo etc. , out of these, which is best? I would like an 18'' bar minimum. Does stihl or husky have a lower priced saw that I am not aware of? I would like to keep the price around $250 or less.
   / chain saw help #2
My experiance with Poulan chainsaws isn't that great, I am sure others have had better luck. I spent more time trying to start mine than using it. I bought a Sthil MS 250 and do not recall it being more than $250 :)
   / chain saw help #3
I'm a big believer in you get what you paid for so I personally would stay away from the Poulan and Homelite saws. I have both a Stihl MS290 and an Echo CS340 and they have both been excellent saws. If you shop around you may be able to find a Stihl, Husky, or Echo around your price point but more than likely it will be a little north of $250.
   / chain saw help #4
I bought a Homelite, and it worked great for a few years, and then it broke. I took it apart, and there was a main shaft that connects the engine to the pull start mechanism, and it was broken in two! There was nothing unusual prior to the breakdown. I was just cutting, and it came to a dead stop.
I bought a Stihl, and I've never been sorry.
   / chain saw help #5
my sthil 028 is close to 20 years,old still runs great.
   / chain saw help #6
I have a poulan cs that I paid $150 for and have used for 5 years, about 20 pickup loads of firewood per winter. Still working fine. On about the 15th chain and 3rd bar. Starts and runs great. Other than bars and chains, all I have done is replace the chain sprocket/clutch housing that wore out.
   / chain saw help #7
Northern Tool sells reconditioned Poulins for $99. A friend buys them and likes them. I'm a Stihl man myself. Brand new Wild things at Walmart are under $150 with 18" bars. Lowes (around here anyway) sell Husky's for $200 and up. But I think all of their saws are under $300.
   / chain saw help #8
Trend seems to be to go Sthil. I've got a sthil 026. 8 years of neglect, abuse, even ran over it with my pickup, luckily I've got big tires and soft ground (big oops and 1 broken handle), and it starts everytime on the first or second pull.
   / chain saw help #9
A 50:1 oil mixture generally denotes a better engine. Echo, Stihl, and Husky use 50:1. I have two Stihl and one Echo and they all seem like great saws. I would recommend to make sure all of your 2-stroke engines (weedwackers, blowers, etc.) take the same oil mixture. Got rid of a Poulan for just that reason. I beleive it was a 35:1.
   / chain saw help #10
028 - excellent saw ! If you can find a nice used Stihl 028 in that price range you'll be ahead of what you could buy for that amount of money new IMHO.
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
(4) HD 16' Pipe Gates (A50515)
(4) HD 16' Pipe...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
