Chain recommendation
   / Chain recommendation #3
I won’t buy grade 43 chains but isn’t every chain hook held on with pins?
Almost every transport chain that I have seen has the hooks held on by pins.
I would go with Grade 70 chain only, unless using for decoration.
3/8" grade 43 is good for 5300 lbs and weights 28 lbs
3/8" grade 70 is good for 6600 lbs and weights 28 lbs
5/16" grade 70 is good for 4700 lbs and weights 19 lbs.
If you do not need the higher weight rating go with 5/16" grade 70, otherwise I would go with 3/8" grade 70.
   / Chain recommendation #4
That’s exactly what I would do. I hate dragging around 3/8 chains when 5/16 is sufficient. I keep 2 grade 80 1/4” chains in my truck toolbox for chaining stuff on my truck bed.
   / Chain recommendation #6
   / Chain recommendation #7
I just did a quick search of Mibro chain.
Grade 30? Decorative, what possible good can this type of stuff do?
Have we lost our minds?
Global sourcing to the very last penny..
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
(INOP) JOHN DEERE 4240 TRACTOR (A57192)
(INOP) JOHN DEERE...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2022 BOBCAT S770 SKID STEER (A52707)
2022 BOBCAT S770...
2011 Ford F-350 Knapheide Service Truck (A55852)
2011 Ford F-350...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
