chain hooks or strap bracket on backhoe bucket
   / chain hooks or strap bracket on backhoe bucket #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Everyone is always posting photos of chain hooks on FELs. Does anyone have a chain hook or strap holder on their back hoe bucket for lifting things. We always have them on industrial hoes at construction sites. They use the hoe to set pipe in the newly excavated ditches and move welding machines around, basically anything that they can reach with the hoe can be moved with the outriggers down. They dont carry it with the hoe. Normally they are welded on the back side high enough up to keep them out of the mud. Sometimes they will weld a hook on the inside of the bucket also to give added mobility to the lift.
   / chain hooks or strap bracket on backhoe bucket #2
Right after purchasing my mini-ex, I welded a 3/8" grab hook to the back of the bucket. It's been used extensively, especially when I removed a downed tree from my chicken run after the October 2011 snowstorm that left us withoutpower for a week.
   / chain hooks or strap bracket on backhoe bucket #3
i welded a big my on my b series kubota backhoe bucket so i can put a clevis on when needed and take it off when digging. i used a 3/4 nut and a 5/8 clevis. cost me $12 total. i also used a 3" peice of pvc 4' tall and put a peice of strap iron bolted to it and now have a cup holder. remember think outside the box. and good luck!
I think I like that nut idea. Never thought of that. Maybe go with a 1" size though so I can use a larger shackle. With that I could use a chain or a strap. Maybe get some use out of that old tow strap I've been carrying in my truck for 5 years still in the plastic wrap.
Now just have to decide where I can keep all this on the TLB so it will be handy when needed.
   / chain hooks or strap bracket on backhoe bucket #5
I've welded a 3/8" grab hook on the back of my bucket, very handy, very handy indeed :D
   / chain hooks or strap bracket on backhoe bucket #6
I add a 3/8 hook to my L39. Kubota even had it in the owners manual that the backhoe has a 1k craning rating. Not sure on the B26 you are getting. It has been very handy.
MarkV
   / chain hooks or strap bracket on backhoe bucket #7
get an old military ammo box and bolt it to the tractor and they are extremely rugged, and keep most all weather out and can hold tools and straps. for most chains i use a milk crate and just put it in the front bucket so they are easy to spot, and paint a color so they are easy to spot and you know whats yours. good luck!:thumbsup:
   / chain hooks or strap bracket on backhoe bucket #8
I've thought about welding a hook on my BH bucket!!!... Just never took the time to do it!
I can see how it would be handy with one or two welded on!!! :)
Bill
   / chain hooks or strap bracket on backhoe bucket #9
If your FEL has a large pipe across the front between the lift arms you can buy a couple of pipe plugs (with a thumbscrew in the middle and an expanding rubber ring on the edge) to seal up the pipe. Then you have a long toolbox on your FEL. The 4" size plug is about $10 at Lowe's.
I had to run about a 1" long weld bead perpendicular to the end of the pipe to get a firm fit without running out of adjustment. The weld is on the bottom so it will let water run out and the pipe to breath in case the chain or whatever is put in wet.
Oh, yes, my 12" backhoe bucket has a weld-on grab hook. May have to add one to the others. Very handy, but my M7040 has a QA boom that also does the same job quite well.
   / chain hooks or strap bracket on backhoe bucket #10
I have been thinking of adding a 3/8 hook to my backhoe bucket. Where did you all weld you hooks on the bucket?
Any pictures would be greatly appreciated.
Electric Mobility Scooter (A51694)
Electric Mobility...
15 - NEW BRAKE DRUMS (A53843)
15 - NEW BRAKE...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2015 ford 150 (A53422)
