Chain Hooks on Loader
   / Chain Hooks on Loader #31
i cut the top of some regular hooks and welded them to the sides of my bucket.
i have more planned, just havnt gotten around to sticking them on
   / Chain Hooks on Loader #32
digger2 said:
I wanted a set of hooks on my B26.But i also wanted the option of being able to remove them if i wanted to.So what i did was weld a set of hooks on
peices of 1/4" thick 2 1/2" x3" plate.This gave me enough room on each side of the hook to bolt it thru the top of the FEL bucket (also 1/4" thick and boxed right from the factory-it should'nt break).
I used a total of 4 (grade 8 i think it was) bolts.If they wont hold,i'm picking up too much.And i can take them off and put them back on anytime i want.Its all up to the individual.
digger2
3RRL-nice job on the BH bucket hooks,i'll have to do that sometime(when i get time).
Amazingly heavy bucket on that B Kubota. Mine on the 7520 is only 3/16 and its a 7klb tractor.
larry
   / Chain Hooks on Loader #33
stimpee said:
Why all the rage to weld on hooks?
Is there a reason why nobody seems to just buy the bolt on type and drill a few holes and bolt them on? If people are worried about the bolts causing localized loads and failing the bucket locally, the same would happen with the weld-on (in my opinion) and if you load it up that much you probably have other problems on the way.
Am I missing something here?
It would seem that drilling 2 holes on the bucket per side, and bolting on the hooks would be easier, and more "reversible" if for some reason you wanted to take them off.
The weld on type just look better ... to Me anyways. But I agree with you stimpee, the bolt on hooks would work well too.
Bob
   / Chain Hooks on Loader #34
SPYDERLK-only the top section of the bucket across the top is 1/4"-not the whole bucket........digger2
   / Chain Hooks on Loader #35
stimpee said:
I asked a question, because I don't understand why everyone seems to go to a lot of trouble to weld on the hooks.
I think people need to keep in perspective how much (or little) load you can actually put on 2 hooks on the bucket with a sub 1k lift capacity.
Speak for your self friend ;) i believe i have 2.2k in my case the welded ones gave an extra point that i use regularly as texas mentioned. I had to move a 8x16' deck that i found in my garden. I used both the hooks and the eyelets to secure that in place to move across the yard. I will probably get to use that again next week when we remove the kerosene tank. Ill get to hoist it and dran the last bit out then haul it to the barn to be set up as my diesel tank :D 2 large straps under the tank to the hooks should about fit the bill
Wonder if i should clean up the inside before putting the diesel in it
   / Chain Hooks on Loader #36
Yes, but if you have a loader with that much loader capacity, you probably also have a bucket that is made more than beefy enough to handle the localized stress of a few bolts going thru it for a chain hook as well.
As I said, I am not stating anything here, other than trying to understand the decisions people make on welding vs bolting. That is all. I can see benefits to both ways, and am trying to understand whether I am missing some key piece of information on either side of the discussion.
So far, I don't think I am, unless you happen to be one of the people with a wimpy bucket that needs reinforcement before ANY type of hook attachment is considered.
   / Chain Hooks on Loader #37
TexasJohn- Any chance of a pic. I am interested in the post driver system you have setup. I think I got a pretty good idea of what you are talking about but a pic would be cool.
Thanks Jim
   / Chain Hooks on Loader #38
Another option for those of you who don't weld. I used a piece of heavy angle iron, drilled bolt holes and bolted to the top of the bucket, then cut three slots in the vertical portion of the angle iron with an angle grinder. One each side and one dead center. The slots catch a chain just like the hook and the force is spread across the whole top of the bucket. There was an old thread in here somewhere that had pics but it's pretty simple.
   / Chain Hooks on Loader #39
More hooks for you viewing pleasure. Takes the load of the bucket. And they swivel.
And a second pic
   / Chain Hooks on Loader #40
rcrcomputing
I really like your setup. I'll have to see if that works on my BX24
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
NEW Long Forks (A59000)
NEW Long Forks...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
