Chain Harrow ???
   / Chain Harrow ??? #1
Odonnks
Kittanning PA
Kioti, Case, Yanmar
Hello all,
When winter subsides I like to get an attachment that will break up all of the horse manure left in the pasture.
Is a chain harrow the correct attachment for this?
Thanks !
   / Chain Harrow ??? #2
I used a 4x4 chain harrow behind my ATV for this purpose. It works well, but I'm planning on getting a bigger harrow to save time. If you're using you're tractor you could essentially get as big of a harrow as you wanted.
   / Chain Harrow ???
Thanks for the feedback !!
   / Chain Harrow ??? #4
i use what they call a chain or drag harrow... it works GREAT at breaking up the horse poop and loosening up the snow mold so the grass grows better.
   / Chain Harrow ??? #5
I know somebody that calls a chain harrow a turd buster:laughing:
   / Chain Harrow ??? #6
Yep, a chain harrow. I asked a similar question on TBN about a year ago. Quite a few responses on various DIY contraptions: weighted tyres chained together; an old steel gate, again weighed down with tyres; etc...
In the end I went ahead and bought an Aussie manufactured one, two 4x4 sections. The first section has tines and the second one is a heavy mesh. I also use it to groom a horse arena from time to time.
Mind you, all that a chain harrow will do in this situation (manure) is to break up the balls and spread it around a bit. I typically follow up harrowing a paddock with my D110 and mulch the spread-out 'goodness'. :)
   / Chain Harrow ??? #8
A few years ago I bought an 8' x 12' chain harrow from a local farmer. It certainly does the job...and quickly...but is a pain to transport, hook up (sometimes untangle!). I think I would have been better off with a narrower one and just take a bit longer on the job.
Bob
   / Chain Harrow ???
Seems like I'm on the right track.
Which ever size I get I was planning on using a 3-pt boom to ease transport and let me raise it to go in reverse if need.
   / Chain Harrow ??? #10
Don't get carried away and get it caught up in the rear wheel. Nasty. I've seen it happen.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 FORD F-250 (A52472)
2019 FORD F-250...
ROCK PICKER (A52472)
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
