Chain Harrow
/ Chain Harrow #1
JoeR
Platinum Member
Central Florida
Kubota L5030HSTC
I need to locate a chain harrow for my Kubota B2710. Where is the best place to buy one? Best price for quality...
I am located in Central Flordida, and I have not seen any local places selling them.
Thanks,
Joe
/ Chain Harrow #3
Not sure where in central florida you are.. but tractor supply carries them.
Soundguy
/ Chain Harrow #4
If you're near Clermont, you can try Fields Equipment on 27.
/ Chain Harrow
I am in St.Cloud, and I did not see any at the local TSC. I looked in their blue book too, and nothing their either.
I will also call Fields...
Thanks!
Joe
/ Chain Harrow #7
That particular store must not have tried hard to find info for you, as their website shows them, and they are also in the blue book for this year.
Of the 3 TSC stores local to me, there is a wide variety of customer service levels.. ranging from 'could care less' to 'great service'.... go figure..
Soundguy
/ Chain Harrow #9
I've seen these implements but never used one. Am I correct in that they are useful in overseeding? Once you spread the seed, you go over it with the harrow to work the seed into the soil so the birds don't get at it?
/ Chain Harrow #10
Exactly right Bebster.
/ Chain Harrow #11
Thanks for the encouragement, cowboydoc. Seems to0 easy: just broadcast spread the seed, and then run the chain harrow over it (and make sure it rains of course). Any other steps I'm missing?
What else is the chain harrow useful for?
/ Chain Harrow
I need it to break up manure piles in the pasture... Overseeding is just another benefit.
Joe
/ Chain Harrow #13
Well there are better ways that you are going to get more germination. But if you don't have alot of equipment that will get the job done. Now you have to make sure that you have proper fertilization, ph, etc.
/ Chain Harrow #14
Are you referring to an "overseeder"? I've seen those and they look like something to have if you owned a golf course!
I do have a 3ph broadcast spreader and core aerator. My plan was to use the core aerator, then fertilize and/or maybe lime if the ph needs it, then wait for a rain so that soaks into the soil, then broadcast seed.
Then chain harrow as you suggest to set the seed into the soil.
I'm not adverse to getting the right implements to help this processes out, if you have any other recommendations.
/ Chain Harrow #15
First of all what is your planned project? Are you interseeding or doing a new seeding?
/ Chain Harrow #16
I've gpt a combination of 3 types of projects (maybe an acre and a half or so of each). (1) established lawn that is thin in a lot of places, and needs to be overseeded; (2) ex-brush land that has been rotary cut and will need to be seeded, in many cases over existing grass that managed to grow, and in others where there is none,and (3) new landscaping around a newly constructed house. Thanks for taking the time to advise.
/ Chain Harrow #17
The nice thing about the drag harrows is that if you are just busting up maneuer.. you can turn it upside down... that is.. have the tines facine up.. it doesn't eat up the grass that way.. but still busts the maneuer clods..
Turn it the other way for a more agressive drag.
Soundguy
/ Chain Harrow #18
Doc Holiday /forums/images/graemlins/grin.gif are these implements useful for knocking down dried weeds late in the year such as died mustard weed growth? If so, would they turn up the soil too much allowing even more undesired growth the following year? What is the best way to keep undesired weeds down on raw land for fire abatement?
I was considering purchasing/making a weed sprayer with large area coverage for the back of my tractor. Currently doing much of my spraying by had (small area, half arce) and mowing the rest during the months that require it (about May - July) here in this dry climate. I'm hoping my tractor purchase will reduce the time spent on fire abatement for about 3 to 4 acres total.
/ Chain Harrow #19
Your best bet over everything is just to get an overseeder. They are pricey though. This is really the only way to realistically get good growth of an existing field. With the little bit of ground you have I would rent one for the weekend. You just can't beat a good overseeder though. All you really have to do there is just make sure your soil is good, ph and fertilizer and plant it.
The second option would be to harrow it really good, broadcast spread seed, and harrow again.
With bare ground the overseeder will work as well.
Second best would be to disc the ground up real good. Then harrow it smooth, broadcast your seed, and harrow again. Anytime you can make a nice seed bed you are going to be way ahead on the germination game.
Depending on where you live it's probably too late to do it this fall. You can plant after Nov. 15th or wait until spring. I'd definitely go over the areas you plan to plant now with your aerator. This will get your soil worked up some before you plant.
The third option would be to get a regular seed drill. These are usually from 10-30'. You can use them just like an overseeder. Best thing about them is that they are alot cheaper if you buy an older one. You can get one in decent shape for $1500-$3000. Problem with this is you kind of have to know what you are doing with one a little more to get them setup right. The overseeder are pretty simple.
Quigley,
Yes the harrow would work to knock down the weeds but you're too late for next year. Those weeds are only annuals. What you need to do is prevent them from going to seed. Best way to do this is keep mowing over the year before they have a chance to go to seed. Spray 2-4D in the early summer late spring to kill all that are coming up. You will need to do this for a few years to get all the weeds killed out from all the seeds in the ground. Usually after a few years the grass will take back over and not allow the weeds to come in.
/ Chain Harrow #20
</font><font color="blue" class="small">( What is the best way to keep undesired weeds down on raw land for fire abatement? )</font>
Lotsa mowing...
Soundguy
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
Exmark Lazer ZX (A64127)
Exmark Lazer ZX...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
2009 Bobcat T190 (A64126)
2009 Bobcat T190...
CATERPILLAR 314EL CR EXCAVATOR (A64277)
CATERPILLAR 314EL...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
