Chain broken on Yanmar RS1200 Tiller
   / Chain broken on Yanmar RS1200 Tiller #1
ohiojr
Ohio
Kubota L2201
I have a Kubota L2100 and a Yanmar RS1200 Tiller. Tiller doesn't work, so I removed the chain case cover and found broken chain and tension arm and nut in the oil. Chain has many cracks as well.
From other posts, I believe the chain is #60 (matches dimensions I measured), but the other hardware is unknown.
Anyone have a diagram for the chain and tension arm? Should I go with some other slide-on tension gadget?
Thanks.
   / Chain broken on Yanmar RS1200 Tiller #2
Yanmar tractor parts catalog
Here you go.I believe this is what your asking for. I have a RS1400 and is Gear Dr. so it wouldn't be much use.
Sorry it took so long I just seen it down here.
Carey
Thanks for the reply. Appreciate the info.
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53472)
2019 Energreen EVO...
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
Gravely 3000 RTV (A51573)
Gravely 3000 RTV...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
