Chain and Binder - general tie down question
   / Chain and Binder - general tie down question #11
How do they determine the WLL on all these chains and binders?
the WLL will be reduced at every attachment point and bend in the chain.
And your tractor might weigh 4500# sitting on your deck but, what will it weigh with all the forces acting on it when you Emergency stop at 55mph.
   / Chain and Binder - general tie down question #12
I work in an place that sells transport chain.... as well as other wear parts for equipment and snow chains....we stock 5/16, 3/8 and 1/2 inch.... 95% of people out there take the 3/8 inch... sometimes they only haul the same thing you haul, but I believe that it is better to play it on the safe side... and if you look at it this way... you also have a good heavy tow/utility chain with you too, instead of light duty chain that might break if you give a good tug on it
WantedWolf.. here is a binder chain specification chart I used. It is in .pdf so I'm not sure it will post here, probably download if you click on it at the bottom of the post.
Also, your question about forces, etc. The quote on the sheet to pick your chain and grade is "Minimum number of chains required to secure loads in a FORWARD direction by weight of the article in pounds". This is based on (as noted) 0.8g of deceleration.
chainandbinder.pdf
  • chainandbinder.pdf
   / Chain and Binder - general tie down question #14
I would defiantly stick with gr70 and probably go with 3/8 over 5/16 its not much more money and when you figure how long its going to last its small piece of mind not only for the safety of your equipment but also the people on the road around you and the hassle of getting pulled over. One stop by the police is enough reason for me to go overkill on tying down my load. GR 70 wont get a second look but something other will and that reason alone is worth the upgrade to me.
   / Chain and Binder - general tie down question #15
Okay, I looked at the chainandbinder.pdf file. For a 10,000 pound load, it says that I need two grade 70 chains. Does that mean two chains on each rear corner (four chains in total)? Or just one chain on each corner?
Ken
How would an inspector know what grade the chain is? Ken
Its stamped on the side of the chain (or if not they know it isn't because it should be).
   / Chain and Binder - general tie down question #17
G70 has a stamp on the chain but doesnt say G70, its usually a little raised mark.
I needed to get to this list done for the trailer insurance purpose anyway so thanks for the motivation guys.:)
This is what I carry on the trailer, (and some pics) and what ive learned is:
-regarding securing the load, I can hold down anything.
-Carrying all this stuff means I have enough remaining GVW to haul a bike.
-Not to mention the Winch, mount, extra spare tire and saddle box that were not present at final weigh in.
The yellow binder in the center is really slick, the salesman was a friend of my FIL and thru it in as a "promotion" when I bought the chains. It is adjustable by the thumbscrew to 3 inchs and it has a locking feature to save mousing. 6600#WLL 3/8 or 5/16 Price tag said $55can.
------Load Binders: Total Weight: 159#
-1/2" Ratcheting (2pc.> removable handle)
WLL: 15000#
Number of item: 4
Single Weight: 17#(2pc)
Total Weight: 68#
-5/16 or 3/8 Locking (yellow)
WLL: 6600#
Number of item :1
Single Weight: 11#
Total Weight: 11#
-5/16 or 3/8 Lever (yellow)
WLL: 5400#
Number of item : 4
Single Weight: 10#
Total Weight: 40#
-5/16 or 3/8 Lever (red)
WLL: 5400#
Number of item: 4
Single Weight: 10#
Total Weight: 40#
-----Chain: Total Weight: 208#
-3/8" X 15' Gr70 Transport + 2 G70 hooks
WLL: 6600#
Number of item: 4
Single Weight: 27#
Total Weight: 108#
-5/16" X 20' Gr70 Transport + 2 G70 hooks
WLL: 4700#
Number of item: 4
Single Weight: 25#
Total Weight: 100#
----Straps: Total Weight: 80#
- 2" X 45' Ratchet Strap (2pc)
WLL: 3300#
Number of item: 4
Single Weight: 10#
Total Weight: 40#
- 2" X 20' Ratchet Strap (2pc)
WLL: 3300#
Number of item: 4
Single Weight: 10#
Total Weight: 40#
Total Items: 29
Total Weight:447#
   / Chain and Binder - general tie down question #18
Any possible laws aside...doesnt common sense say that more opportunities for failure (murphy's law) occur when more variables are introduced. I am refering to 4 binders instead of two. We know that the cam type binders can release and ratchet type threads wear plus the 4 more hooked points.
If an engineer looked at a 4 corner binder setup and ran a DFMEA, the back binders would be scratched.
If you just have one chain on the front and one on the back and one breaks there is nothing at all holding that end of the tractor.
   / Chain and Binder - general tie down question #19
You misunderstood the post, When I say binder I mean chain binder not chain.
   / Chain and Binder - general tie down question #20
Just a "heads up" on a good price, I have discovered the local HomeDepot carries a 5/16" X 20' Grade 70 "binder chain" for about $40.00. Hard to beat that price if shipping is involved :D
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
Pickup Truck (A59230)
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
