arrow
Super Member
Anyone know how this rating works? Why are ratings of cfm's higher at lower pressures? If a compressor is rated for 8 cfm's at 40 lbs, is there enough stored air in it's 30 gallon tank to run a 10 cfm consumption tool?
CFMs are higher at low pressures because a compressor has a compression ratio. Most air goes to the tank, but some air is left in the cyl after each stroke. That residual air is at whatever tank pressure is at the moment. The compressor must now take a new lung full of air to compress, but its intake stroke is starting out with a little pressurized air in the cyl. The 1st part of its intake stroke must expand this residual to below atmospheric before it can start to suck in new air. The higher the tank pressure gets the more of the intake stroke goes to waste this way.Anyone know how this rating works? Why are ratings of cfm's higher at lower pressures? If a compressor is rated for 8 cfm's at 40 lbs, is there enough stored air in it's 30 gallon tank to run a 10 cfm consumption tool?
