Century Problems
/ Century Problems #21
Micropilot, I think Lynn is probably describing your sensation. Try this experiment sometime; find a shallow (6-8") depth and narrow ditch and drive across it at a diagonal direction. If one of your wheels loses contact with the ground you may fell a lurch until the tractor catches traction again. This happens fairly frequently to me when I cross a ditch to go into my garden plot on the other side of the dirt driveway. Willie Jones
/ Century Problems #22
I will add to the last post that even in 4wd that this can happen if crossing something ruff enough to cause one front and one rear wheel to lose contact (they just spin).
2014 PETERBILT 389 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A68363)
2014 PETERBILT 389...
2012 Kubota R520S (A64911)
2012 Kubota R520S...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
2023 TAKEUCHI TL10V2 SKID STEER (A65056)
2023 TAKEUCHI...
11.2-24 Tires - Set of 4 (A68134)
11.2-24 Tires -...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
